Hey guys. I recently read a thread about changing power steering fluid and I'll change mine tomorrow. I am looking to get Mobil 1 Automatic Transmission Fluid which is recommended but I can't find one around my place (Huntington Beach, Socal). So the alternative way is to get Dexron III compatible. Below is the links:
http://www.oreillyauto.com/site/c/de...id+-+synthetic
http://www.autozone.com/autozone/acc...questid=437921
http://www.autozone.com/autozone/acc...er=232570_0_0_
Dexron III, Matic J compatible. Does it mean that they are safe to use as Power Steering Fluid? Thank you.
Well, I dont get the part Dexron III-H or Dexron III-D... and they are for GM cars. Can someone explain about this?
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
When I added my custom p/s tank I used OE fluid that I purchased from Nissan. When changing p/s fluid you'll never be able to remove 100% of the old and I wouldn't mix them because you might cause a leak in your rack....
Buy OE p/s fluid from Nissan....my two cents!
Gary
Gary
Ok, So I'll go to Nissan dealer tomorrow and ask them for P/S Fluid. I know that I will not be able to remove 100% fluid. How to avoid leak? Thanks for your input.
^ lol, Nissan Fluid is just Dexron III fluid. Anything compatible will mix just fine. I have not heard of anyone changing it out and having a leak.
