HKS RS, LS+ Coilovers built in camber adj?
Re: HKS RS, LS+ Coilovers built in camber adj?
You guys are like ..posting in future and stuff - uh huh huh
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Yup, agree with protocav. You can only get camber adjustments with a strut type setup. We have a double wishbone type suspension up front with a multi link in the rear. For camber adjustments, you would have to get an adjustable upper arm for the front (350evo, Kinetix, Perf. Nissan, etc.) and adjustable upper link for the rear.
04.5 G35C TB/Graphite 6 speed, XM Radio, Premo Package, Navi, OEM Chin Spoiler, Hard wired V1
Was checking out the HKS site and if I'm reading correctly, their coilovers for the Coupe (RS and LS+) have built in camber adjustment. Can anyone confirm this for the Coupe? And if so, can the camber be adjusted to nominal stock specs? Thanks.
Not the LS+, I have them and I don't see any camber adjustment.
03 G35 Coupe: Check my profile for the spec./05 ???(No more STI)
I have LS+ as well... I bought Stillen Rear Camber+Toe arms and it helps a lot.. I think LS+ and RS is same...
<font color=blue> DG 04 Coupe "Impuls+HKS S.C Coming Soon", Black 04 Accord Sedan 4 Daily!</font color=blue>
built-in camber adjustment is only possible on macpherson strut-based suspensions, where the strut is connected directly to the top of the spindle. our suspension setup does not allow for camber adjustment through the shocks, and no set of coilovers will have it.
i have the LS+ also.
Chad
Chad
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
