Spark plug oil *pik*
Old Apr 4, 2011 | 11:37 PM
loki05's Avatar
that picture about was cylinder #6, which is by the driver side corner.
The entire valve cover was replaced on the driver side, I checked the passenger side and it was bone dry so only the driver side that was leaking was replaced.
Old Apr 4, 2011 | 11:40 PM
doeboy's Avatar
Yeah I'm out of warranty which blows and mine has 106k. I was hoping the spudering was coming from a fouled spark plug. I thought I was right until I reached that last cylinder on the passengers side of the car. I was like FML...
Old Apr 5, 2011 | 05:08 AM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by doeboy
If I were to buy said kit above. 150 +100 core charge, is the install easy or should I take it to a mechanic?
Are you comfortable with basic hand tools? If so the installation is relatively easy. It just takes a while and you have to be very careful as you will have to remove a lot of little stuff to get to the valve cover. I'd say it's a 3/10 on the difficulty scale. If you're going to do that buy a 1 7/8" hole saw bit and fix your original cover with just the seals.
Old Apr 5, 2011 | 05:55 PM
doeboy's Avatar
Ok cool. I'm pretty good with my hand tools. I saw a DIY for the drilling and installing the seals but is there one for removing the valve covers?
Vqalexisz
Oct 14, 2015 12:48 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
TNRocker
Sep 21, 2015 08:36 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
