Spark plug oil *pik*
Old Nov 5, 2010 | 10:13 PM
loki05's Avatar
the oil is not directly in the spark plug hole, but when I pulled out the coil pack there was some oil I believe around the edge where the red arrow is pointed towards, is that normal?
Old Nov 5, 2010 | 10:18 PM
thescreensavers's Avatar
Mr.202?
Yes, Valve gaskets need to be changed, its covered under powertrain warranty.
and man what if people would look at stickies.
https://g35driver.com/forums/g35-cou...rranty-up.html
Old Nov 5, 2010 | 10:31 PM
loki05's Avatar
yeah I saw that post but theirs were inside the spark plug area instead of at the edge of the coil pack area that's why I was wondering if its the same symptoms
Old Nov 5, 2010 | 11:21 PM
Chealy's Avatar
Yours looks considerably cleaner than the ones posted in the thread mentioned above. I would say your fine unless you found oil in one of the other plugs. But I'm no mechanic...
Old Nov 5, 2010 | 11:28 PM
loki05's Avatar
yeah its pretty clean inside, but at the edge where the red arrow is pointed there is oil there, and I'm not sure if there is suppose to be there.
I'm going in for the airbag recall so I mind as well do this if the oil isn't suppose to be in that area.
BTW is having sxexcx grounding kit installed fine to leave on? or will they make a big deal about it causing problems to the valve area which cause it to leak oil? lol
Old Nov 6, 2010 | 01:12 AM
herrschaft's Avatar
I doubt they will care if you have a grounding kit installed.
Old Nov 6, 2010 | 06:46 PM
the_sedan's Avatar
if you're still under warranty, get it fixed. thats a sign that the spark plug tube seals are leaking. once it gets worse, the oil will pool up around the plug and coil boot.
Old Nov 6, 2010 | 11:05 PM
herrschaft's Avatar
The fix is to replace the whole valve cover and not individual seals correct?
Old Nov 7, 2010 | 03:54 AM
MM_G3520's Avatar
Correct!
Old Apr 4, 2011 | 02:55 PM
thatattguy's Avatar
My car has this too, so is this good or bad? Bring this thread back to life lol. Im not burning oil last i checked but i do leak it haha. I dont lose any oil between changes exept for maybe 1QT every 3500 miles (i blame the leak and blow by).
Old Apr 4, 2011 | 06:28 PM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by 03BaseSedan
Correct!
If OP is handy with tools there is another alternative to replace just the seals for about $60. https://g35driver.com/forums/vendor-...lve-cover.html
Old Apr 4, 2011 | 06:33 PM
herrschaft's Avatar
I remember seeing that thread a little while ago.
Old Apr 4, 2011 | 10:53 PM
BW350GTskyline's Avatar
is this cylinder six? because i read that usually this occurs on that cylinder for this engine.
Old Apr 4, 2011 | 11:04 PM
herrschaft's Avatar
^Thats normally where it starts, but it can happen to all 6
Old Apr 4, 2011 | 11:25 PM
doeboy's Avatar
I'm not sure which cylinder is 6 but mine has oil in the one by the spark plug closest to the battery and firewall. I can somewhat feel it sputter a bit here and there as well. If I were to buy said kit above. 150 +100 core charge, is the install easy or should I take it to a mechanic?
