Best replacement spakplugs?
Old Nov 9, 2010 | 05:53 PM
vinco's Avatar
I changed mine out at 105K. A week before that, I was driving slowly in a school zone one day, in 4th gear at about 30 mph. All of a sudden, it just died on me, going down the road. I was able to just coast into a parking lot safely, and it did restart with quite a bit of cranking. When I pulled the plugs, every one of them had the gap worn out to about .085", where the stock plug gap for new ones is .045". It was no surprise at all to me once I saw that wear that the engine died. Plugs normally wear about a thousandth of an inch per 2K-3K miles (as in the gap widens due to electrode erosion.) There is a point at which the coils simply cannot make the spark jump the gap. Personally, I went with the Denso v-Power platinums, and I haven't had a problem since.
Old Nov 9, 2010 | 09:55 PM
VQ Johnny's Avatar
OEM is platinum hence the 105k service interval, platinum last longer than irridum, copper etc., check your owners manual.
Old Nov 9, 2010 | 10:15 PM
gary c's Avatar
I believe our coupes came with NGK Platinum PLFR5A-11 (Gap set at .044)
Gary
Old Nov 9, 2010 | 10:25 PM
ShaneH85's Avatar
Gary
This is the plugs I recently purchased to replace my old ones. Hopefully it will be running smooth after I get it back from the warranty work done, oil in both #3 and# 6 cylinders
11bEMT
May 27, 2022 03:13 PM
ara777
Aug 15, 2018 04:11 AM
snic09
Nov 8, 2017 01:46 PM
miata007
Aug 17, 2015 04:36 PM
35reilly
Drivetrain
Aug 6, 2015 12:40 AM
