Where's my power?
He's still probably got less power than a car running in warm weather at sea level, but I highly doubt it's anywhere near 20%... probably more like 2 or 3% given the fact that it's probably at least a good 40 to 60 degrees cooler there now than it is in Florida on most days.
If you don't feel your car is fast. Pull up next to a Prius and floor it. Slow down, wait a couple minutes, then watch the Prius slowly pass by, then floor it again!
The power is there, the car is just too comfortable to let you feel all of it.
Weight is also a little bit of a issue. Regardless I love my coupe!!!!
If I had my G35 again, I probably wouldn't trade it for an Evo. You pretty much give up all of your luxury and other nice features for mere speed. Put it this way, speed is something you would rarely use (unless you're a full out track car). But all of those features on the G35 is someone you would use everytime you're in the car.
So don't worry if you don't have the fastest car in the world. All the girls that I give rides to in my car almost always complain that its way too loud. Most girls like to ride in silence. Not to mention luxury.
Not in the winter it isn't.... I bet the cold temperatures in Colorado right now in comparison to Florida sorta balance out the fact that Colorado is so much above sea level.
A stock g35 5000 feet above sea level will produce roughly 20% less power than a stock g35 at sea level...given equal temperatures.
Since our engines consume roughly 14 parts of air for every part of fuel, and there's less air available in a given volume at 5,000 feet than at sea level, no tune is going to fix the fundamental problem. The mass airflow sensor is already compensating for the lack of air density.
Forced induction is the only direct solution to the fundamental problems presented by lower air density. Forced induction is the only thing that can make the air the engine is consuming more dense.
Looks like 2.5 p.s.i. of boost would make my g35 produce the same amount of power in Denver as it would at sea level - given equal temperature and humidity levels.
Here's a link to a thread posted by another Colorado resident who wasn't pleased with his g's performance. Ultimately altitude sickness was the diagnosis.
Very well. I should have used Northern lower Michigan instead of Florida for my comparison. It is true that temperature, as well as humidity, plays a role in how dense air is.
Thank you for this quote! The day I lost to a stock cobalt SS supercharged was the day I relized how much altitude affects my car! And it SUCKS! FI car loss way less power than an NA car!
Here's something else to consider. Since at 5000 feet you're already giving up roughly 3 p.s.i. over what you'd have at sea level, if/when you go forced induction your first 3 p.s.i. of boost are effectively "free" from an engine stress/reliability standpoint.
In other words, you should be able to run say 8 p.s.i. of boost just as safely as someone at sea level running 5 p.s.i. - because you're both running a net boost increase of 5 p.s.i. beyond what the stock engine is engineered for.
Hope that makes sense.
This is not true. 8psi is 8psi, and 5psi is 5psi. The internal pressure of a turbo charger is independent of the outside air pressure. If the boost gauge reads 8psi, then the turbo is just working a bit harder to make that 8psi at 5000 feet than it would be at sea level.
I'm afraid I don't remember off the top of my head, but the answer is somewhere in this thread.
https://g35driver.com/forums/drivetr...tial-swap.html
