Can't fill up with gas sometimes?!
Old Jan 29, 2011 | 05:43 PM
  #31
jibberjabbers's Avatar
Pics is in the TSB link I provided.
Old Jan 29, 2011 | 09:14 PM
  #32
tibasnatch's Avatar
a bit different ....today I had to fill my tank up for the first time....the light was on for the past 15 miles or so......i would only take 17 gallons and then stopped....we have a 20 gallon tank right? ???
Old Jan 30, 2011 | 03:41 AM
  #33
RiversideS13's Avatar
Thank you for this useful information! that looks kinda hardcore btw..... i have a short hand, i hope i can make it.
Old Feb 14, 2011 | 03:21 AM
  #34
Does anyone know how much does Riverside Infiniti charge G35 drivers for this TSB?
Old Feb 14, 2011 | 11:11 AM
  #35
BW350GTskyline's Avatar
i have the same problem.. but if you dont want to spend 100 bucks or what ever for the sensor... A trick i picked up when your at the gas pump instead of putting the nozzle in the proper way flip it upside down so the handle is facing upward rather downward works every time..
Old Feb 14, 2011 | 11:18 AM
  #36
davidxu's Avatar
it used to do that to me at every gas station I go to. i went to get it fixed under warranty, now it just does it at 1 or 2 gas stations...
makes me thing the gas station also has a part in this
Old Feb 14, 2011 | 04:08 PM
  #37
speedjunkie_G35's Avatar
The recall is only for the fuel line. This should be done as it can cause a fire.
The "filling" issue has nothing to do with the fuel line, but a "Fill Limit Vent Valve". This is not a recall. But a TSB was released for this.
TSB #: ITB08-041A.
Download PDF here: http://www.infinitig37.com/TSB/1SC29.pdf
This affects 03-08 Infinti vehicles (M, G35, G37).
After this was performed on my car, I no longer had any problems. So it's not the gas pump that was the problem, but the car itself. I mean, I never had any problem with my previous cars filling up the tank.
I was curious in the TSB link in parts list, it shows the cover as the part that needs to be replaced. I would think it was the FLV valve that causes the problem and needs replacing
Old Apr 28, 2012 | 09:30 PM
  #38
akoustic's Avatar
I've got the very same issue by the way. Worse now that my local gas station changed the pump nozles...
Can you imagine the FLV or the shield drops over the to other side of the tank? (if it is possible...) Eeeeeeeeeeeeeeek....
Old Apr 29, 2012 | 11:40 PM
  #39
g35ryn23's Avatar
I have this problem also but it will only kick in when my tank is more than half full. Pretty much what I do now is put gas when it is below the 3/4 line and it doesn't seem to be a problem
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
