Weird noise while accelerating?
Old Nov 19, 2010 | 12:47 AM
cHink's Avatar
I have a 06 G35 Coupe 6MT first time and had it for about 1month and 7 days now and love the ride but hating how its turning ugly.
I start to have problem when im accelerating.
with my windows down, Everytime 1st and 2nd gear, both reving at 2k RPM theres like a rattle noise while accelerating. It only does that 2k RPM. Wtf? Anyone know whats the problem?
Also i'm taking my car to the nissan dealership for a checkup and its free for a check up to see whats wrong with my car right?
Old Nov 19, 2010 | 03:43 AM
socalwdup's Avatar
Not free. Don't go. $150 for check up.
Rattle can be easily fixed by taking apart the window.
Search the DIY here
Old Nov 19, 2010 | 08:19 AM
SC23x's Avatar
I'm not so sure it's the window, the same thing happens to me.....
It sounds like it's coming from the engine, but could be a heat shield.
Old Nov 19, 2010 | 09:50 AM
cHink's Avatar
it cant be the windows and dont think it is.
it happens to me while im accelerating only at 2k rpm with 1st and 2nd gear only. Ill have a video later today
Search the DIY here
Is infiniti dealer free for a check up then?
Old Nov 19, 2010 | 10:23 AM
R10T_x's Avatar
no such thing as a free dealer check up unless ur in that 10 day grace period lol
Old Nov 19, 2010 | 10:25 AM
cHink's Avatar
well i use to own a honda before the infiniti and honda dealer gave me a free checkup on what i need to change or replace while they were doing my oil change.
Old Nov 19, 2010 | 10:44 AM
R10T_x's Avatar
keywords are use to/honda/oil change and they only did like a 12 point inspection during that oil change...which they will do at infiniti also but when u tell them u have a weird noise coming from the motor their gunna charge u 100 bucks to check ur problem (diagnostic fee) if theres even a problem regardless ur out 100 bucks
Old Nov 19, 2010 | 11:27 AM
DiGil's Avatar
I've had the same issue for a while now on my 05 6MT. You could try checking to see if any heatshields are loose, if so tighten them down. Otherwise, our flywheel tends to be noisy, so maybe that's it.
Old Nov 19, 2010 | 12:28 PM
G2FLIP4's Avatar
everything
Its the transmission in the 6MTs.... they're extremely noisy... get used to it.
Old Nov 19, 2010 | 04:19 PM
cHink's Avatar
Originally Posted by G2FLIP4
Its the transmission in the 6MTs.... their extremely noisy... get used to it.
I didnt know the transmission rattles while accelerating through 2k RPM at gears 1 and 2. So its normal or something if you hear that rattling noise?
And btw wheres the heat shield located at so i can prolly try tightening up to see if my problem is fix.
Old Nov 25, 2010 | 10:06 AM
Jstin120's Avatar
Had the same problem and also thought it was a heat shield. Check your oil level. Turned out the noise was coming from the engine becuase I was really low on oil. Hope it isn't the problem.
Old Nov 25, 2010 | 10:24 AM
Pedrog35's Avatar
i have the same rattle....because of my act flywheel...maybe the last owner of your car installed a flywheel and u just dont know about it....good luck
Old Nov 25, 2010 | 08:51 PM
NVM's Avatar
NVM
Seems like so many people recently buying 6mts are having problems within the first 2k mile or less
Old Nov 25, 2010 | 09:39 PM
pwestbball11's Avatar
I had the same problem in my 2005 coupe. I took it to dobbs and they ran a diagnostic finding nothing. One of the guys there said it was a heatshield and he adjusted it and it never has made the noise sense. He did it for free also.
Old Nov 26, 2010 | 01:19 PM
lcysimon's Avatar
May I ask which headshield?
