'04 G35 Coupe Passenger Window Acting Up
Old Nov 23, 2010 | 03:03 PM
mdmaiorano's Avatar
Question '04 G35 Coupe Passenger Window Acting Up
Searched around and couldn't find an answer to this one guys! Thanks for the help in advance...
Noticed last night that the passenger window is acting up. When you try to use either set of controls in the cabin, it won't budge and I don't even hear it trying to go up or down. I know the motor isn't bad because when you open/close the door it still goes up and down a little to seal it.
If I'm not mistaken, it can't be a fuse because that would mean the driver side wouldn't work either (which it is working fine). I even tried the old "punch the door in the middle" trick with no luck.
I'm stumped, and figured I'd ask here before sadly taking it into the dealer for another bill to pay.
Thanks!
-Mike
Old Nov 23, 2010 | 03:11 PM
Frankieg35's Avatar
The window motor is shot.. it will still go up when u close the door..
Old Nov 23, 2010 | 03:13 PM
mdmaiorano's Avatar
son of a...looks like off to the dealer I go!
I am somewhat handy though, makes any sense to try to do it myself or is there some calibration that would be too much of a pain in the ***?
Old Dec 30, 2010 | 04:41 PM
prell's Avatar
I second the bad motor! they can act in an intermittent way when they are about to take a crap. Double check there is no binding too, sometimes the window frame can be a little loose causing the motor to shut down temporarily.
Old Dec 30, 2010 | 04:50 PM
Blue Dream's Avatar
I drove ttrank's car solo
You can buy a new motor fairly cheap at an auto parts store. AutoZone has them with a lifetime warranty for ~ $125 here. Install's pretty easy as well.
Old Dec 30, 2010 | 04:52 PM
nogoodname's Avatar
Buy this for 160 shipped!
https://g35driver.com/forums/interio...ator-bnib.html
Old Dec 30, 2010 | 05:46 PM
Blade Runner's Avatar
Make sure the window lock isn't on. Sounds silly but happens all the time.
Old Dec 30, 2010 | 06:10 PM
410g35's Avatar
You can try tapping (lightly) the motor with a hammer or something to see if it flinches. Works with starter motors sometimes.
Old Dec 31, 2010 | 09:46 PM
1FSTG35AT's Avatar
I tried to clean mine but i think the brushes were just in too bad of condition so off to the dealer I went to spend 300 bucks... Thank god for boost, makes all those trips to the dealer sooooo worth it!!!!!
Old Jan 4, 2011 | 04:00 AM
andrewstclair's Avatar
wow the auto parts place near me sells me the rebuilts for 120. and if u searched this topic and didnt find anything then your search button is broken theres about a million threads on this topic this is like the most common problem next to the a/c sticking on lol
Old Jan 10, 2011 | 08:39 AM
Jester296's Avatar
Just dealt with this yesterday on my 03 driver side. Went down but never went up. Took the door apart to find the front window bolt was loose and caused binding which burnt out the motor. Very easy to take apart and change. Advanced Auto Parts has the motor for around 130. Ill be replacing mine soon. Good Luck
laksjd84
Jul 24, 2015 05:12 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
wylin
Lights
Jul 18, 2015 06:12 PM
