04 g35 coupe vdc slip lights wont go away
Old Dec 1, 2010 | 11:19 AM
skylntt's Avatar
before anyone says something i have done searches, its not the brake pads i have done a reset of ecu, it wouldnt go away after i put on drilled n slotted rotors and got an alignment. befor i take her in to infiniti for a $400 bill just to tell me what the problem is any suggestions ??? ooo and its not fluids checked it all !
Old Dec 3, 2010 | 06:38 PM
05Scoobyroo's Avatar
Auto or Manual? have you actually checked all of the pads on each caliper? Only reason I ask is I've had a rear outer brake pad look perfect, yet the rear inner pad was completely shot.
Old Dec 3, 2010 | 09:15 PM
the_sedan's Avatar
get the codes checked.....maybe a etc or cam sensor?
Old Dec 3, 2010 | 10:02 PM
THE G35's Avatar
I had the same issue and I went thru 100000 threads with all the same answes such as
Brk pads
Low brk fluid
ABS sensor and so on
My problem was the god damn alignment. Got is fixed no more problems.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Jusseth
Sep 13, 2020 12:25 PM
igking
Jul 19, 2015 01:12 AM
attarday
Jul 15, 2015 04:03 PM
