Finish installing stillen/z-tube. Does it look right? (PICS)
Old Dec 4, 2010 | 01:01 PM
DrewLe's Avatar
That's it. You can't physically move the AC line. To protect it, just wrap some foamy packaging material around it, that's what I did.
Old Dec 4, 2010 | 04:58 PM
cHink's Avatar
what kind of foamy package you use?
Old Dec 4, 2010 | 09:18 PM
DrewLe's Avatar
It's like the foamy packaging material that comes in rolls or sheets.
But essentially, you can wrap anything around the AC line to act as a barrier between the z-tube, AC line, and engine bay.
Old Dec 4, 2010 | 09:28 PM
Project's Avatar
Goto home depot and go into the plumbing section. They have foam tubes that protect the water lines in a house in different sizes. Just get a close fit and your good to go.
Old Dec 11, 2010 | 04:03 PM
bulletproofpat's Avatar
Looks good to me. So much better than the stock setup.
Old Nov 1, 2011 | 12:58 PM
thepro78's Avatar
Originally Posted by *****
Uhm i just took off the ECU(not unscrewing the screws) i was trying to hard to take it off but i finally took off the plug. I didnt unplug the Negative battery, will anything go wrong?
So here is the picture that i just finish installing a few minutes ago and i think it looks right. Tell me if anything is wrong with it. I had a hard time of figuring out which way is the Z-tube cause the stock G-Tube hose is pointing up and tryna figure out which way does the Z-tube hose faces.
im not sure if this is the ac line you guys want to protect but this is a picture i took this morning and it is very close to my tube. I have read the JWT Pop Charger thread about protecting the AC Line but i tried to move it and it doesnt even move.
where did you get the heatshiled// intake box for this? does it come included with the ztube kit or is it an extra part
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
EPG35
Aug 16, 2015 04:52 PM
Phenomenon9
Aug 9, 2015 01:34 AM
