PLZ HELP... Car Shakes when I stop but drives normal. What can it be?
Old Dec 17, 2010 | 08:16 AM
adamls2's Avatar
Im thinkin bad gas or dirty intake but if it was from the hfc's it would just make a rattleing sound not shake the entire car. I say try a new intake filter and if that doesnt. Work reset ecu and if its not back to normal then stealership time :/
Old Dec 17, 2010 | 04:46 PM
jwolfpk's Avatar
It's not hfc cats because mine did it before I for my cats and mine isn't from air filter cuz I changed mine twice I think it's a air leak
Old Dec 17, 2010 | 05:36 PM
gqraverice's Avatar
Could it be oil in the spark plug tubes? I know many of us have had the seals in our valve covers go bad.
Old Dec 17, 2010 | 07:55 PM
DJM AutoWorks's Avatar
just a quick easy fix if you want to try disconnect the battery both terminals then hold the terminals together for about 5 minutes and then reconnect it and the cycle the key 2 seconds on and then 10 seconds off and repeat three times this may help... if not...
if you clean the throttle body your going to mess up the idle anyway and probably make it worse... you need to clean the throttle body and then do an idle air volume learn... also you have to make sure that you adjust the timing back to 0 because the computer has a tendency over time to advance or retard the timing but usually it advances to 1 degree... also if you have an intake on you should bump up the base idle to like 800rpm... all of this can be done on the consult 2 or 3 at the dealer as long as you have the right tech that knows what he is doing...
also just a slight possiblity you could have a bad power steering pressure switch which could be triggering an irratic idle but not a high idle...
if non of this works you probably have a bad throttle body so just change it very common problems on nissans and infinitis
: dancedancedanceicon30icon30icon30icon3 0icon30icon30icon30icon30icon30:
Old Dec 17, 2010 | 09:56 PM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by Footballmania32
^Don't lose the straw in the plenum like that one guy did hahaha
One of the most epic opening posts of a thread ever.
Today, I cleaned the throttle body using the Sea Foam Deep Creep. While I had the butterfly valve open, I tried to spray the solution and the red plastic straw flew off inside the throttle body. I could not see or get this plastic straw out. So, I put everything back and drove around without any issue. Does anyone have any idea if this going to cause problems later on? Thanks for any advice.
Old Dec 17, 2010 | 10:34 PM
jebus2006G35's Avatar
thanks lot guys for ur help. i have my OEM intake right now. i did have a CAI before but it never did it. I already did the reset or comp, idle, thro..... it hasnt done it anymore. so will see. i did put a LUCAS cleaner. it only has 40k. so hopefully it doesnt do it again. still no SEL. ill update u guys. =)
Old Dec 17, 2010 | 11:47 PM
Bri127mx's Avatar
jebus2006G35, are you going to sell me your double din kit?
Old Dec 18, 2010 | 12:56 AM
jibberjabbers's Avatar
Could be anything. Check your sparkplugs for oil
Old Dec 18, 2010 | 01:04 AM
Project's Avatar
I had it too turned out my throttle body needed to be cleaned horribly. Took some cleaner used a finger and did my thing. Reset using procedure and it was fine. Starts up and actuall stays on without gas. Crazy.
Old Dec 18, 2010 | 03:08 PM
cool. i been so busy i havent cleaned it. i havent checked the Spark plugs. im afraid 2 find oil. it hasnt done it for 2 days. will see
Old Dec 19, 2010 | 09:35 AM
musti82's Avatar
there is already another thread with the exact same issue, check out that one too!
Old Dec 20, 2010 | 11:05 PM
sorry bro. i sold it
Old Dec 20, 2010 | 11:08 PM
sorry for the late reply guys. my internet sucks. my spark plugs are good. =). i took off T.B and cleaned it. i did the reset. so far so good. but will see. its been raining all week. im going 2 put back my injen. see what happens.
Old Jan 3, 2011 | 10:08 PM
i did everything and it still did it. I installed my Injen CAI again. so will see what happens now.
Old Jan 4, 2011 | 03:38 AM
  #30
andrewstclair's Avatar
sounds like a dirty idle air control on the throttle body i would say first step is to clean that then do your plugs if it continues.
