driver's door problem
Old Dec 22, 2010 | 07:34 PM
STILLENDoutG35's Avatar
So this happened today. I cant open my drivers door when i am inside the car but i can open it when im outside. Its like there is a child safety thingy on the driver door. Has anyone ever experienced this?
Old Dec 22, 2010 | 07:52 PM
Gdriver90's Avatar
make sure that latch from the inside is still connected to the lock mechanism
Old Dec 23, 2010 | 02:41 AM
What do you mean by the latch being connected to the lock mechanism? Doesn't it connect when you set the unlock and lock button on the remote?
Old Dec 23, 2010 | 10:59 AM
xyz999's Avatar
Remove the plastic door panel and you will see the latch, make sure it's hooked up properly.
Here is a DIY, just look at the first few photos for door panel removal procedure:
https://g35driver.com/forums/body-in...l-removal.html
Old Dec 23, 2010 | 04:42 PM
EnerOnE's Avatar
similar thing is happening to my drivers side. It doesn't work sometimes or if the person doesn't open the door all the way it gets stuck at the not open/not closed point. I haven't searched into it yet but hope someone gives some info here.
Old Dec 23, 2010 | 05:31 PM
If you could post pictures of how the latches are supposed to be connected ill appreciate that. Thanks
Old Dec 24, 2010 | 11:43 PM
room12's Avatar
Where can i purchase an jdm infiniti double din a/c controller w/ climate control for an 04 g35 coupe
Old Dec 24, 2010 | 11:50 PM
Scone's Avatar
1st check thread (just saying, not trying to be a dick)
2nd, I've seen several on the marketplace. I got mine off www.mynismo.com
Hope that helps
Old Dec 29, 2010 | 08:13 PM
atmel101's Avatar
I would open up the panel, it should be pretty easy to identify the problem
Old Dec 30, 2010 | 12:29 PM
pythonjosh's Avatar
There are 2 cables that go to the interior door handle housing. The lower one is the door lever, upper one is the door lock cable.
It is only secured using a metal ball at the end of the cable and it fits into a little holder behind the lever.
Should be a piece of cake.
mike730
Jan 12, 2018 04:25 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
