04 G35, Stalling/loss of power/hard to start/ CEL, VDC, SLip! FML!!
Old Jan 3, 2011 | 06:11 PM
spacecitygroove's Avatar
i replaced the crank sensor an hr ago.
Car runs perfectly now.
Thanks everyone
Old Jan 3, 2011 | 06:29 PM
TannerG's Avatar
Good to hear. Thanks for posting the results.
Old Jan 3, 2011 | 06:48 PM
yes sir, very easy to replace!
it fixed the problem immediately.
cranked over and started instantly,
Old Jan 3, 2011 | 07:01 PM
kyemaul's Avatar
Thanks everyone
Great to see everything worked out! Just to be sure you changed cam or crank sensor. Did you go to nissan or infiniti?
Old Jan 3, 2011 | 07:57 PM
i did it myself in less than 30 mins.
all the issues just disappeared instantly when i connected the new crank sensor..
Old Jan 4, 2011 | 01:35 AM
BW350GTskyline's Avatar
good to know... thanks for the heads up there kaymeul +1
Old Jan 4, 2011 | 02:08 AM
also wanted to add, that my car feels more responsive to the throttle..
It feels a little more powerful.
Maybe its just me?
Old Jan 4, 2011 | 10:46 AM
kyemaul's Avatar
Maybe its just me?
Thats great! I dont think it would give you more power. I think its just your butt dyno giving you high readings. LOL
Old Jan 4, 2011 | 11:46 AM
well not more power, per se.
But it feels alot more responsive, The gas pedal is real sensitive.
I touch it and the car leaps from a standstill.
Never used to do that...
Old Feb 14, 2011 | 06:26 PM
brenty_blanco's Avatar
Same results here!
Just replaced my crankshaft sensor (had the P0335 error code)
Car feels way more responsive, all dash lights (CEL,Slip,VCD) turned off..
However, now it seems like I have to hold the key over for an extra sec or two longer than I ever had to before to start it.. Anyone experience something similar?
Car starts and runs fine now, but the hesitation when its turning over is killing me! Any help?
Old Feb 14, 2011 | 07:02 PM
vinco's Avatar
I didn't do a crankshaft sensor, but I did a cam sensor last week. Results were much the same - more responsive, better power, seems much easier to rev now. I luv my G again!!!
Old Feb 16, 2011 | 12:04 PM
g35Davo's Avatar
yikes
Old Feb 16, 2011 | 12:20 PM
Canadian's Avatar
Canada, eh?
Crankshaft sensors go bad all the time on our cars.. I'm on my 3rd
Old Mar 19, 2012 | 09:01 PM
mannys_g35's Avatar
I had had the same problem with the camshaft sensor. Everytime i want to step on it, my car bogs and all the lights turn on(vdc, slip, and check engine). I first replaced the crank shaft and the problem stopped for a few weeks. Then it did it again, this time it was the bank 1 camshaft. I replaced 3 times already and continues to bog when I step on the gas. Doesn't give me a code for bank 2. What else can I do? Any suggestions are appreciated. Thnx in advanced.
Old Sep 9, 2012 | 03:20 PM
  #30
blAk mAx's Avatar
Anyone know if you can have a bad cam sensor without throwing that specific code?
