Problem with climate control
Old Oct 30, 2004 | 05:58 PM
gersteinp's Avatar
The interior temp setting in my base 6MT coupe seems to be 3-4 degrees F lower than the actual cabin temperature. That is, when I set the climate control to 68, then cabin gets up to 72. Also, when I drop the temp down to cool things off, it seems to take forever unless I go down to 60 or 61 degrees. Is this a common problem? Is there a way to calibrate the interioir temp setting? Or is this a defective climate control unit? Thanks!
2003 G35 base coupe DG/W 6MT, clear corners/drilled pedals/z-tube @ 6400 miles.
Old Oct 30, 2004 | 07:04 PM
Msedanman's Avatar
O.F. Administrator
Re: Problem with climate control
Our climate control system seems to have a mind of its own sometimes.
I'm sure that there is a way to regulate the system if out of spec, but you'll have to get the dealer to do it.
C.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Nov 2, 2004 | 03:02 PM
gersteinp's Avatar
Just got back from the dealer where they recalibrated my system AND taught me how to do this myself. To recalibrate the climate contro (CC)l:
1) Turn key to ON and turn CC off
2)Turn key OFF and then ON and leave ON
3)Hold down the CC OFF button until readout changes to the calibrate mode.
4)Tap TEMP up until the end (number 51 will show)
5)Hit DEFROST button and then the fan UP button
6)Calibrate up or down by 6 degrees using the TEMP button. For example, "-3" means that the cabin will be 3 degrees cooler for a given temp setting.
7)Exit calibration mode by hitting AUTO
There are probably other settings that can be changed in this manner but I don't know how to do the other changes.
2003 G35-6MT base coupe DG/W with Z-tube, clear corners, drilled pedals @ 6900 miles.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
erickLA
Aug 18, 2015 04:46 AM
TreeFiddy
Aug 10, 2015 06:50 PM
