anyone know a solution to remove rust from black door panels?
Old Jan 10, 2011 | 08:23 AM
mtlg35's Avatar
Hello everyone,
I have a DG g35x 2005...
I am having alittle problem with rust invading my door panels. Since then it gives my car a older not maintained look
Does anyonee have a solution to remove rust on the panels?
thank you in advanced
Old Jan 10, 2011 | 08:40 AM
Irrelevant's Avatar
Rust is like cancer for a vehicle. It must be cut out, or the panel replaced, in order to stop it. If it's very light surface rust that hasn't eaten deeply into the metal you might be able to sand it out, treat the area with a rust inhibitor found at your local auto body supply store, then prime and repaint the area.
Short term you could just paint over it, but it will continue to eat away at the metal under the paint until you have a bigger problem to deal with. This method is not recommended.
This advice comes too late for you for this particular issue, but for future reference it's wise to get touch-up paint on any paint chips a.s.a.p. to help prevent rust from getting a foothold.
Old Jan 10, 2011 | 09:42 AM
gary c's Avatar
Autoparts stores have an item that stops rust, not sure how it works but that's something worth looking into if your rust issue is minor.
Gary
Old Jan 13, 2011 | 06:14 PM
mtlg35's Avatar
ok in that case, anyone know where to buy the black door panels???
Old Jan 14, 2011 | 01:32 PM
TannerG's Avatar
Wait... What's rusting? It sounds like you are talking about the interior of your car. Surely you don't have black doors on a DG sedan, do you?
Maybe I'm missing something...
Old Jan 15, 2011 | 06:19 PM
mtlg35's Avatar
nah... its on the exterior of the car. The black panels on the door moldings
Old Jan 15, 2011 | 06:30 PM
M@rCo's Avatar
pics?
Old Jan 16, 2011 | 01:40 PM
Kuneff's Avatar
Try some CLR (Calcium, Lime & Rust) its in a grey plastic bottle and you can get it almost anywhere... Lowes, home depot, walmart and so forth... I have used it before and it worked good for the things i used it in/on. just let is soak, it will/should kill the rust and keep it from coming back for a while.
Old Jan 16, 2011 | 02:03 PM
jibberjabbers's Avatar
Take it to the dealer. The car should still be under "corrosion" warranty. It's 7 years from the date the car was originally purchased.
skippyG
Jan 25, 2016 01:18 PM
will091195
Jul 27, 2015 09:19 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
Blakelyg35
Jul 24, 2015 08:51 AM
emorehs
Jul 17, 2015 09:45 AM
