RPM question
Old Jan 13, 2011 | 01:27 AM
05skyline's Avatar
RPM question
Recently I noticed that it seems that my engine is running at higher RPMs then in the past. Right now its at 2700rpm @ 70mph....3000rpm @ 77mph. It idles around 700rpm. Is this what your engine is running at?
Old Jan 13, 2011 | 01:37 AM
fstasfk_G's Avatar
mine runs about 2800 at 80mph
Old Jan 15, 2011 | 12:16 AM
05skyline's Avatar
hrrmm....at 80mph mine is around 3200. Wonder y?
Old Jan 15, 2011 | 11:37 PM
fstasfk_G's Avatar
i know on my previous cars, i can adjust the throttle line thingy from under the hood to control the rpm... just loosen it
Old Jan 16, 2011 | 12:42 AM
Igaly1021's Avatar
ok but what gear are u guys in when doin' 80 5th or 6th?
Old Jan 16, 2011 | 01:45 AM
Reidonly's Avatar
My '05 6MT coupe is at about 3100-3200rpm in 6th gear at 80mph.
Old Jan 16, 2011 | 02:20 AM
OGKushRob's Avatar
me as well, no worries man haha
Old Jan 16, 2011 | 02:45 AM
bluedevils95's Avatar
Would elevation be the problem?
Old Jan 16, 2011 | 03:23 AM
Tricky-Ricky's Avatar
Depends whether your MT or auto as the ratios are completely different.
Old Jan 16, 2011 | 03:39 AM
I really never pay attention to the RPM unless i am in trickmatic
Old Jan 16, 2011 | 11:50 AM
V35 Skyline GT's Avatar
6MT Coupe
75 mph = 2800 rpm with 285/30's in the rear on my 6mt in 6th.
Old Jan 16, 2011 | 07:59 PM
urkaput's Avatar
3000rpm on the dot for 80 mph, and 5 mph drop per 200 rpm. Ex. 2800 for 75, 2600 for 70. Wish it was closer to 2000 for 80 and save some highway gas. Stock tire size.
Old Jan 17, 2011 | 10:43 PM
Reidonly's Avatar
I miss that about my LS1 Camaro... 6th gear at 80mph was about 1800rpms. 6th gear at 100mph was only about 2400rpms lol. I barely even used 5th or 6th around town, the car would just stall from being so low in the rpms.
Old Jan 18, 2011 | 07:49 AM
Jatwell1's Avatar
Exclamation Rpm
I have a stock 07 g35 and at 45 mph I am running 2000 rpm, but I don't know if this car has a lock up torque converter, my dash just says D. This is the first G35 I have owned. Please help, this just seems high to me compared to the previous cars.
Old Jan 18, 2011 | 08:59 AM
GrocryGettr's Avatar
There is no sensor, relay or adjustment to that would allow your car to change rpm at a given speed. If your car is an auto, then possibly your trans is not shifting into 5th, but I doubt it. Run your car in manual mode and make sure it shifts into 5th.
If you have aftermarket wheels and/or tire sizes on your car, you can go to http://www.miata.net/garage/tirecalc.html and it will tell you the difference between stock and aftermarket sizes.
