V3 Vortech SC kit
Old Jan 13, 2011 | 09:33 PM
GeezNuts's Avatar
Originally Posted by the_coupe
just get the tuner kit, dw 600 injectors, walbro pump, osiris tune on a stock nonrev motor will put you right at 390-400 on the stock pulley.
i disagree with that.
considering i am running a rev up with supporting mods and am just north of that number
OP - if 350 is your goal i would think that you might be close to that with the full kit and some supporting mods - what else do you have done to your car performance wise?
Old Jan 13, 2011 | 09:34 PM
the_sedan's Avatar
get a compression test done, if your numbers are within range then you'll go zoom for a good while lol. if not, it'll be zooooooBoom. if you dont tune after the install, then boom. haha
Old Jan 13, 2011 | 09:35 PM
Frankieg35's Avatar
Haha!! Hope all goes well..
Old Jan 13, 2011 | 09:36 PM
GeezNuts's Avatar
Originally Posted by franklucas
Car: 2003 G35 6mt coupe 70k miles
I have purchased a Vortech V3 SC kit with FMU and Fuel pump.
I am fairly mechanically inclined and I am doing the install myself. I have read the install manual several times and feel comfortably with the install. Here are some of my questions:
1. Vortech claims the car will run fine with the SC in stock form, is this correct?
If not what do i need to upgrade not to gain more power but to run safely.
This is a daily driver I just want some more pop! No track runs here.
2. After the install do i need to take it to a dyno to have it tuned by a pro?
I am on a budget and the local guys wants $1200 to tune it.
3. I have read to run a colder plug close the gap a little etc what
other small tips should i be aware of?
Thanks for the input guys/gals I have read some posts here about 3 hours worth and there is a lot of help here thanks.
when installing the tolerances are VERY tight, especially with the intercooler/intake piping - it will take some time to get it to sit right... bring alot of patience with you while installing, don't rush!
Old Jan 13, 2011 | 09:37 PM
the_sedan's Avatar
sooooo.....i get first dibs on the kit in the future. haha
GeezNuts's Avatar
ha ha - well said!
Old Jan 13, 2011 | 09:42 PM
franklucas's Avatar
so with tuner kit i need to buy fuel pump and injectors then take to tuner for around 700 i can get it tuned?
Old Jan 13, 2011 | 09:43 PM
franklucas's Avatar
everything is still stock.
Old Jan 13, 2011 | 09:44 PM
the_sedan's Avatar
just relaying what i was told by dude at CIN when he installed and tuned a stock nonrev with that setup. he said like 390 and 370. maybe its just how well the tune is done
Old Jan 13, 2011 | 09:46 PM
the_sedan's Avatar
yeah franklucas, it also wouldnt hurt to get an oil pan spacer to give you that extra oil capacity but not necessary since you're running a v3.
and if i were you id put an exhaust and spacer on there to get full potential of your tune. the stock cats are a huge restriction, an aftermarket exhaust/headers are plenty better than stock, and a 5/16 or 1/2 md plenum spacer is almost a mandatory mod these days
Old Jan 13, 2011 | 09:51 PM
GeezNuts's Avatar
It could be and how hard they are pushing it -
Although i still doubt that claim of 390 on a non revup motor with just the stock pulley on a stock engine. Be curious to see a dyno of that.
The tuner kit, 3.11 pulley, 600cc injectors, plugs, walbro 255 fuel pump and a tuning software - UTEC or Osiris would do you wonders, i think you will be alot more satisfied with that set-up than the stock full kit.
I also recommend the HFC's, exhaust and a plenum spacer - you'll be in the intake manifold putting in the injectors, be a simple add on to put on the spacer at that time. Headers are a giant pain on our cars, but that would complete the exhaust side and give you nice gains and sound!
The oil pan spacer isn't necessary since your going V3 - self contained oil... might look to dremel some of the support area for the bumper near the headlight/fender so you can pull the dipstick to check/add oil to the supercharger a bit easier, it's a pain otherwise...
Old Jan 13, 2011 | 09:54 PM
the_sedan's Avatar
what he said /\ id run osiris over utec tho.
prolly true kricci.
Old Jan 13, 2011 | 09:59 PM
GeezNuts's Avatar
check this post out - it is the single greatest thread i have ever read concerning the Vortech:
http://my350z.com/forum/forced-induc...questions.html
Old Jan 13, 2011 | 10:23 PM
Silencer_0's Avatar
^+1 on that thread. I've read it twice already and it sounds like you need to read it before you go off buying and installing parts.
Old Jan 14, 2011 | 01:41 AM
  #30
TemjinX2's Avatar
Just get a good dyno tune from a tuner with a good reputation. The tune will make or break your build.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
n2fooz
Sep 4, 2015 07:46 PM
