Will these nuts fit?
Old Jan 20, 2011 | 09:39 AM
breezerboat's Avatar
I searched, but couldn't find an answer.
Will 12X1.25 lug nuts fit on a 2005 G35 with 19" factory wheels?
Thanks in advance.
Old Jan 20, 2011 | 10:28 AM
These are the ones I am looking at.
http://cgi.ebay.com/ebaymotors/20PC-...mZ260443454319
Old Jan 20, 2011 | 12:27 PM
G35_Brian's Avatar
yes they will fit. pretty much anything with a thread pitch pattern of 1.25 will fit on the factory 19's.
Old Jan 20, 2011 | 03:27 PM
saywat?'s Avatar
can someone explain how does one know if they can put tuner lugs on oem wheels? i always thought the golden rule is u cant
Old Jan 20, 2011 | 05:56 PM
TofuProductions's Avatar
.. what.
yes you can.
Our cars need 12x1.25.
Don't get 12x1.50 they won't fit.
Old Feb 10, 2011 | 07:05 PM
Buju On Friday's Avatar
What about putting stock lugs on aftermarket wheels? As long as they fit the hole is it OK?
I'm about to get MRR Gt-1's and wondering if I need to get new lugs also or if I can used stock lugs for now...
Old Feb 10, 2011 | 07:10 PM
kennymo's Avatar
im using stock lugs on my mrr gt5s
Old Feb 10, 2011 | 07:13 PM
G35_Brian's Avatar
as long as it tightens down the wheel you can use any lugs pretty much.
Old Feb 10, 2011 | 07:14 PM
4DGS's Avatar
It's not recommended.
There are usually to styles of lug seats
Tuner style
Sits like this \__/
and Ball style
Can't really draw it but it's a lot more like this (__)
it has rounded edges and not hard taper, most OEM wheels require ball and can't use tuner style lugs. But it seems infiniti found a happy medium that accepts both styles.
A lot of aftermarket wheels will not allow ball seats though.
Old Feb 10, 2011 | 07:39 PM
VictoriousG's Avatar
hahaha I came in this thread thinking it was something else *NO HOMO*
Old Feb 10, 2011 | 10:30 PM
Da_KiiD_cT's Avatar
OP Thats what she said!!
Old Feb 10, 2011 | 11:27 PM
seymore4's Avatar
m56
wow you seriously want to put those lug nuts on your Infiniti?
Old Feb 11, 2011 | 06:48 AM
Old Feb 11, 2011 | 10:21 AM
Tikiman12's Avatar
Tuner style
Sits like this \__/
and Ball style
this is what you need to know
however the factory lugs use the "tuner style". I just installed some myself, takes 10minutes.
Old Feb 11, 2011 | 11:17 AM
jstudrawa's Avatar
Anyone know a good locking lug nut set?
Either a 4pc of just the locking nuts
Or a decent 20 piece full set including locking nuts
I'd like a sharper set on the OEM 19's, and while i doubt my car will ever be up on blocks in from wheel thieves, I'll admit to paranoia
J
