valve cover, spark plug well gaskets....on eBay?
Old Jan 29, 2011 | 06:03 AM
Blue Dream's Avatar
I drove ttrank's car solo
There is a thread about these guys and the o-rings.. Seems legit..
IIRC you had to drill out the old gaskets with a 1 7/8" hole saw and then these supposedly fit in the new hole. I'll look for the thread to see if I can find it.
Old Jan 29, 2011 | 06:12 AM
Blue Dream's Avatar
Here's the post I was talking about:
Originally Posted by R&D Factory
your warranty should and will cover leaking valve cover o-rings grommets. we do advise you to check for leak before your warranty is over.... the whole idea of us making these o-rings grommets were for those who have leaking o-rings grommets yet their warranty is already over. we do drill out the old o-ring grommets with hole saw size 1 7/8 inch. its is slightly bigger than the existing hole and slightly smaller than the o-ring....please pm us if you have any further questions....thank you
60 for 6 o-rings
90 to add OEM valve cover gaskets (both side)
100 to add OEM pcv valve and seal
above prices are shipped to lower 48 states.....
Thread found here: https://g35driver.com/forums/engine-...ampaign-5.html
Old Jan 29, 2011 | 03:04 PM
jibberjabbers's Avatar
60 for 6 o-rings
Clearly states you have to drill out the old gasket.... Anyone know if a Maxima Valve Cover would work on our G35 Coupe? Same engine and it's only 35 bucks for the cover.
JoeMac
Aug 20, 2015 10:17 AM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
yassy
Aug 9, 2015 07:31 PM
ghost_g35
Aug 7, 2015 10:31 AM
lemmy999
Jul 25, 2015 12:13 PM
