what can i do more after a supercharger and cams?
Feb 10, 2011 | 01:59 AM
  #31
yep, rob from ZCG. i'm currently running the 3.12 pulley. I had the 2.87 on when i originally installed the kit, but rob was concerned my boost level was too high for the stock block
Reply 0
Feb 10, 2011 | 02:02 AM
  #32
ooo ok... how much difference is it from 3.33 to 3.12
Reply 0
Feb 10, 2011 | 03:03 AM
  #33
OP, you can also run shorter gearing in the diff.
3.70 or 4.08?
It'll give you the feel of having moar powaaaagh
Reply 0
Feb 10, 2011 | 03:09 AM
  #34
Quote: OP, you can also run shorter gearing in the diff.
3.70 or 4.08?
but then i'll loose my top end speed rite?
Reply 0
Feb 10, 2011 | 03:10 AM
  #35
yeah but who really goes 158mph on a normal basis?
Reply 0
Feb 10, 2011 | 03:12 AM
  #36
yea thats true but do you know how much you loose on top end?
Reply 0
Feb 10, 2011 | 03:40 AM
  #37
I'd check My350z for that one. There aren't too many G owners that have changed out differentials.
A lot of Z owners have though.
But my guess would be 8-10 mph
Reply 0
Feb 10, 2011 | 12:43 PM
  #38
Quote: ooo ok... how much difference is it from 3.33 to 3.12
2-3 psi of boost depending on your mods.
Reply 0
Feb 10, 2011 | 03:04 PM
  #39
Quote: 2-3 psi of boost depending on your mods.
kool ima ask rob to see what pulleys i got and if i can go to next one...
Reply 0
Feb 10, 2011 | 05:50 PM
  #40
Quote: kool ima ask rob to see what pulleys i got and if i can go to next one...
Chris wat mods do u have?
Reply 0
