G35 project cage and slam
Old Feb 27, 2011 | 10:10 PM
  #31
DogStar's Avatar
Looks awesome. Definitely curious on the report for the stance arms too... didn't know they made those!
Old Feb 28, 2011 | 05:33 AM
  #32
AlexAZD's Avatar
Originally Posted by 4DGS
OH ****, didn't see the update of it being done lol
Looks fantastic, what ideas you have for paint so far?
thinking either:
gold, copper, orange, bronze
I love them. everyone that has seen them has just said WOW. they are beef. Call Pete at intense. He can order them up for you. I love those arms. Hopefully they will make traction and a-arms soon.
Old Mar 2, 2011 | 04:08 AM
  #33
AlexAZD's Avatar
So here is some Dry Ice...
Here is some clean up work on some areas...
The dry ice was super quick... Hopefully I will have the interior clean this weekend to prep for some more welding then paint.
Old Mar 2, 2011 | 09:14 AM
  #34
adamls2's Avatar
niuce!!!!!!!
Old Mar 3, 2011 | 08:25 AM
  #35
AlexAZD's Avatar
So something I have been wanting to do is remove some wiring. There was so much of it. Tonight I didn't want to do the same **** as I have been doing. So I only removed seam sealer for about an hour or two and I moved to dewiring the car.
Here is some pics of some of the clean up I did on the rear saddle.
Here is a little preview of the wire stripping. Looks much better now.
This is what is left of the driver side chassis harness
This is what I took out... It literally felt like 6-10 lbs of ****. (I own a mastiff, I know what 10lbs of **** weighs.. ;-)
Old Mar 3, 2011 | 09:02 AM
  #36
iamericgee's Avatar
wow looks like a **** load of work
Old Mar 3, 2011 | 10:28 AM
  #37
walshtj's Avatar
Wow nice progress and love the mastiff reference. I almost bought a little french mastiff puppy a few months ago!
Old Mar 3, 2011 | 12:03 PM
  #38
The Stimulation's Avatar
Subscribed. Awesome work.
Old Mar 3, 2011 | 05:44 PM
  #39
monteitis's Avatar
Pretty impressive, but this thread would be way cooler if there were z-tubes and popchargers involved.
Old Mar 3, 2011 | 05:58 PM
  #40
AlexAZD's Avatar
Z tubes and pop chargers? I dont know what to say to that except why would I want z tubes or a pop charger when I already had a greddy twin turbo kit and I am switching to a powerlab single custom turbo setup? I would not do all this to a car only to put parts that would only give 10whp? Whether those are the numbers are not is the the discussion here.
Old Mar 3, 2011 | 06:38 PM
  #41
zackt69's Avatar
rarejdm.com
Did you remove the airbag control module (box that is under center console)? I only ask because it looks like you removed some of the airbag wiring and connectors, and I'm curious to know if removing the module will cause any weird BCM issues. My car's gutted and caged too, I'd like to clean up all the excess wiring as well.
Everything looks great btw!
Old Mar 3, 2011 | 06:47 PM
  #42
AlexAZD's Avatar
Yes I did remove the airbag connectors and the module. I'm really debating doing a painless wiring setup and custom gauges. I'm going to see tonight if it's possible. I don't care to run stock gauges anymore and all I need a RPM, water temp, and gas.
I've seen your car. Looks good. I'm going to be at REMIX Irwindale, will your car be there?
Old Mar 3, 2011 | 07:03 PM
  #43
zackt69's Avatar
rarejdm.com
Thanks, for the response and the compliment, I appreciate it! I was looking into custom wiring before, but after reading a few threads on my350z, decided it might be a little bigger project then I wanted to deal with. I remember reading something about the alternator not charging the battery when the cluster was removed, or something ridiculous like that. If you could get it figured out though, you'd definitely be able to clean things up a lot more.
Unfortunately REMIX falls on my anniversary and I'll be out of town... wife already made plans.
Old Mar 3, 2011 | 07:16 PM
  #44
AlexAZD's Avatar
Hmm... that should be something to look at with the alternator. With the Cann bus it causes a big problem from what i've heard. But i'm at a point it might be required lol. I will see when it happens. I just traced back everything that I wanted to keep and follows back the things I didn't want. I'm also going to run it through the walls of the frame and under the door to hide everything.
Old Mar 4, 2011 | 02:38 AM
  #45
G35_REDLINE's Avatar
NICE!! Cant wait to see more!!
