coilover help (rear shock hight )
Old Feb 13, 2011 | 09:26 PM
d.dineane's Avatar
I have g35 coupe with bc coil overs and the ride hight is fins but how do you adjust the shock hight .I feel like the shock is not doing it job , there has to be a formula to doing this . Help please
Old Feb 14, 2011 | 01:33 AM
dukehotty's Avatar
I can only help you with "height" but hopefully Simulation or Candlepark will chime in.
Old Feb 14, 2011 | 07:02 AM
Blue Dream's Avatar
I drove ttrank's car solo
You probably need to play with the dampening settings on the shock if the shock is your concern. What issues are you having? Please post up more specific info on the shock not doing it's job so we can help.
Old Feb 14, 2011 | 08:05 AM
Snakes' G's Avatar
Sounds like u are asking about the length of the shock. You need to adjust the shock length to match the spring. U just loosen the one collar on the shock and turn the body of the shock. I unbolt the bolt at the bottom of the shock to make it easier to rotate.
Old Feb 14, 2011 | 11:22 AM
d.dineane's Avatar
thank you Snake g. The ride hight (spring) is perfect but i'm not sure about the shock hight for the rear on the coupe. so u saying what ever the hight is for the spring i should measure the spring hight and make that the hight for the shock?
Old Feb 14, 2011 | 11:32 AM
Snakes' G's Avatar
I jack up the spring bucket till the spring doesn't wobble then adjust the shock length so I can bolt it back in. Not 100% sure if this is perfect but it feels good. I had the same problem when I first put them in my shock was way to compressed at normal ride height. Hope this helps. Your rideheight should not change when u Just adjust the shock.
Old Feb 14, 2011 | 11:49 AM
d.dineane's Avatar
I will try this .
Old Feb 14, 2011 | 12:00 PM
d.dineane's Avatar
btw i called bc and they said I compressed the shock to much and i should measure from the bottom of the fender to the center of the wheel hub,then that measurement and apply that to the shock .
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
si_driver
Aug 11, 2015 07:08 AM
wuppiedog
Aug 7, 2015 11:16 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
