car wont start when turning key.
Old Feb 14, 2011 | 09:28 PM
Draven83's Avatar
Hey everyone, Well i am watching my friends 04 G35 Coupe while he is on leave. And there have been a few times when i turn the key that it wont do anything. Yes i press the clutch, i have tried putting it in gear and also neutral and still wont do anything. Has anyone had this problem? What do you think it might be?
Chris
Old Feb 14, 2011 | 09:30 PM
the_sedan's Avatar
do the lights and everything come on? if so and it doesnt start. try hittin the clutch down hard.....more than likely the clutch switch on the pedal.
Old Feb 14, 2011 | 09:31 PM
Draven83's Avatar
radio and everything works good. and ive tried slamming the clutch pedal down but it just wont do anything. it has me at a loss.
Old Feb 14, 2011 | 09:40 PM
the_sedan's Avatar
can you push start it? find the clutch switch....hold the ign key to the start pos and keep pressin the clutch switch in with your hand as many times as you can. if it wants to start, then thats your problem.
Old Feb 15, 2011 | 02:32 PM
mojo9's Avatar
Is it turning over but not firing?...if so, is the anti-theft light on solid while it is cranking? If that's the case, the ignition is not recognizing the chip in the key & may need reprogrammed, it happened to me. It was an intermittent problem
Old Feb 15, 2011 | 02:33 PM
saywat?'s Avatar
does ur buddy kno or say that u can take the car out if u need to? maybe he thought it wouldnt move so he did something to prevent it from starting so it wont get stolen.
Old Feb 15, 2011 | 02:35 PM
Draven83's Avatar
nah he told me to drive it while i was looking for a car. yea its intermittent. happens every now and again, its done it to him a few times also. Im gonna have him try to get the key reprogrammed when he gets back
Old Feb 15, 2011 | 02:38 PM
saywat?'s Avatar
my bet is the clutch switch then. either its defective or not pushed down all the way. why dont u try and push it with ur hand while turning the key or have someone turn the key? jus look at the clutch pedal and u can see the switch.
Old Feb 15, 2011 | 04:45 PM
IHIERBal's Avatar
Had this issue with my 04. Safety switch under the clutch pedal went bad. Very cheap from infiniti and easy to change as well.
Old Mar 4, 2011 | 12:00 AM
nissandrifter32's Avatar
Thumbs up
I have an 03 and my engine wont crank unless i hit the clutch down real hard. My first though was the Starter is taking a crap but after reading this thread i think i'ma replace the clutch switch...
Old Mar 4, 2011 | 04:44 AM
partyman66's Avatar
Your buddies starter is on the way out. The solenoid is sticking.
Carry piece of wood with you and a hammer, and the next time it does this, put the piece of wood on the starter and smack the other end of the wood with the hammer kinda solidly. The sudden jarring motion will often temporarily free a stuck solenoid. If this makes it work, the starter needs to be either rebuilt or replaced.
Also check your connections on the battery to make sure they aren't all caked with battery acid and ensure they're tightly fastened to the terminals.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
kenthung
Jul 21, 2015 05:56 AM
