HVAC goes to A/C choosing Recirculation
Feb 20, 2011 | 05:45 PM
Is this the default behavior on this car? I don't have an owners manual. Two things that happen that I'm not sure they are supposed to be happening:
1.) When A/C is not on, and I press the mode button a much of times it changes where the air gets blown. As soon as I get to the foot area/defrost icon on the display, the next time I press the mode button it sets the A/C on.
2.) If I have the heat up, I live in Canada, and I try to set it from 'pull air from outside' to 'recirculate inside air' it automatically goes to A/C. Its like -30 here and takes forever to warm up. I just want it to heat the air inside and keep circulating that as apposed to pulling in cold air to heat. As soon at the a/C light comes on, I press the A/C button to turn it off and it jumps back to the 'pull air from outside' setting.
Reply 0
Feb 20, 2011 | 08:40 PM
Yes, that is default behavior.... One of the many fun quirks of the G35!
Reply 0
What year is your car?
1. our cars AC doesn't have a "recirculate" function like most cars do.
2. same as #1
I believe this applies to 03-06 cars and 07 coupes.
Reply 0
Feb 20, 2011 | 09:19 PM
Its an 03. I do have a "recirculate" button, but it only seems to come on with the A/C selected.
Reply 0
Feb 20, 2011 | 09:23 PM
It's normal... my '05 does the same thing when I hit the recirculate button as well.
Reply 0
Feb 21, 2011 | 07:54 AM
my '03 is the same way aswell and it does bug me at times. Someone told me to go ahead and let the A/C button light up, and the compressor will only engage if youv'e selected a lower temp w/ your climate selector. I thought I heard the compressor cut in even with the temp at 85 so I just got used to having no recirculate option with heat.
Reply 0
Feb 22, 2011 | 12:58 AM
i have a 03 also and it does the same when i hit the recirculate button, the ac turns on. normal occurrence on the g.
Reply 0
