ART pipes vs ...
Old Feb 24, 2011 | 09:44 PM
  #46
Xet's Avatar
Xet
Originally Posted by sTeadFasT96
Lets keep this on topic right? Springs seem to be the topic, nothing more nothing less. Also it'd seem to make more sense that coilovers which contain components made for each other would work better than a very generic strut setup with general springs. I doubt people from Tokico planned on having struts that specifically worked with Tein H springs.
My point (to make it clear) is that lowering springs by themselves (which is what was originally asked and appears to be the topic of discussion) are not as functional in terms of handling performance relative to OE sport suspension.
Edit: In regards to your response to the other guy about brakes and suspension. I completely agree with you, but the aftermarket spring selection for our cars are once again SOFTER or very progressive compared to the OE springs, so wouldn't that be counter productive considering the general rule of thumb is that a reasonable amount of stiffness is desired?
But the fact that you bring in coilovers and that price line would assume that you could afford struts to pair with your springs. There are quite a few threads on here discussing the performance of independent struts vs coilver pairings. I admit I was surprised when I first saw the arguments and research for independent struts but it is very compelling.
Old Feb 24, 2011 | 10:31 PM
  #47
Kyle318's Avatar
could have sworn this thread was originally about test pipes....and if you're going to spend the money lowering your car, either get coilovers or shocks AND lowering springs. Don't be a cheap *** ricer and just get a set of Eibachs......YOU DRIVE AN INFINITI NOT A HONDA!
Old Feb 24, 2011 | 10:44 PM
  #48
Xet's Avatar
Xet
lol... wow even getting worse. Why can't he buy springs and then get struts later? He will have to do a bit more work taking pretty much everything back out but so what?
Old Feb 25, 2011 | 12:31 AM
  #49
Th3R3dStar323's Avatar
because stock struts suck **** thats why lol, he can do what he wants but its better to just go straight to the coilover system, at least IMO.
Old Feb 25, 2011 | 12:45 AM
  #50
walshtj's Avatar
Wow, didn't realize I would create so much controversy.. Anyway I plan on getting hotchkis sways and endlink. I also have confirmed my agree idea of going with z stechs, thanks to FederalG!! And lastly I have to go with the Noob, Enboyx Id much rather do my cats now and do my suspension all at once(sways, drop, camber, endlinks).
Originally Posted by xdEnbOyx
So OP, unless you plan on auto-crossing, the benefits of HFC/TP are much higher than springs and camber and can be utilized much more. Personally I like to push it pedal to the metal off the line or getting on the freeway rather than taking a corner at the maximum speed my car can physically handle. If you don't plan on doing the latter or aren't concerned about the apparent 4x4 look some people claim everyone who doesn't have "dumped" cars have, get the ART pipes.
TL;DR: HFC/TP > Suspension for DD purposes IMO.
But thank you everybody for your input and continue discussion is ofcourse wlecome!
Old Feb 25, 2011 | 12:50 AM
  #51
Xet's Avatar
Xet
I don't get it, you said you are going with sways and endlinks but then you would rather do art pipes and then later all suspension at once....
Also don't bother doing sways/endlinks with camber and drop unless you are paying someone to do it all at once for cheaper. It makes no difference to performance to do them separately.
so because stock struts suck you can't change springs and then struts later? congratulations that makes no sense.
Old Feb 25, 2011 | 04:31 AM
  #52
really it makes no difference? changing out the struts to an upgraded strut with improved dampening or dampening control, makes ALOT of difference.
if your going to change the springs you might as well do the struts too, why wait and do it seperatly? You will end up taking up more time and money doing that, but if thats what you want to do then so be it. lol
Old Feb 25, 2011 | 05:54 AM
  #53
Footballmania32's Avatar
I installed my springs first, and am actually in the process of buying some Tokicos. I did them seperately because I've been waiting for the right deal on the shocks. Brand new, the price is ridiculous. I've saved myself hundreds by waiting, thats sometimes why people decide to do them seperately. Hell if money wasn't a issue I would just get coils.. But unfortunately it is. But I refuse to install low quality parts on my car, so I am simply forced to wait around until the right sale comes along.
Old Feb 25, 2011 | 10:29 AM
  #54
well i guess if you dont mind waiting for that perfect deal then its all good lol
Old Feb 25, 2011 | 10:47 AM
  #55
Xet's Avatar
Xet
Holy crap are you freaking kidding me? It won't make a difference in the end if he does a few pieces separately. Yes he will have to jack up the car again, take off the wheels, and unbolt the strut and take off the old spring in the fronts but that takes what maybe 2 hours max?
Old Feb 25, 2011 | 01:54 PM
  #56
sTeadFasT96's Avatar
Doesn't matter if he does springs then struts or both at the same time. In the end it'll yield the same results.
Personally, if you can afford a full setup, I'd just recommend just saving up a bit more and going for coilovers. Also, in my opinion at least, unless you plan on auto-x'ing a lot, going on mountain runs, tracking etc. a lot, then suspension definitely is a must before any power mods, but most of us (assuming) don't do that often enough. OE sport suspension is plenty to accommodate the spirited run every now.
I spend more time in the power band than I do pushing my car through peak G's.
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
NyCrAzY
Oct 1, 2015 09:19 AM
