driver door rubs
Re: driver door rubs
I have the same problem. Dealership denies its existance. Assuming you have a coupe... basically your window isn't rolling down 1/4 inch when you open the door and the mechanism inside of the door is wet. I just use the palm of my hand and gently push the window down before closing the door. Makes the problem go away, but it's a PIT-butt.
