How to make shifting more smooth?
Old Mar 1, 2011 | 02:02 AM
moto_za's Avatar
Question How to make shifting more smooth?
I just had a my clutch and flywheel changed which I enjoy, but I was wondering if there is any way I can do something to my car /shifter to be able to shift more easily and make it more bubbly and smooth? Thank you.
Old Mar 1, 2011 | 02:50 AM
almost3flips's Avatar
I just ordered a weighted shift **** and should be here Wednesay. I'll update you if it improves my shift experience
Old Mar 1, 2011 | 02:57 AM
Xet's Avatar
Xet
bubbly???
What are you exactly going for? I'm not sure what you are searching for but ss clutch line, weighted ****, and rogue shortshifter are all mods most people enjoy..
Old Mar 1, 2011 | 06:13 AM
Tricky-Ricky's Avatar
Was your clutch peddle readjusted when the new clutch was fitted? as this could be the problem making it harder to shift.
Was an uprated clutch fitted? there are a lot of things that can influence the way it feels, however "bubbly" is not one of them
Old Mar 1, 2011 | 10:35 AM
gary c's Avatar
One sure way to make your MT shift better would be to change trans fuild to RedLine synthetic. If your clutch/flywheel were installed correctly using synthetic fluid should make it feel better than new....happy trans!
Gary
Old Mar 1, 2011 | 11:05 AM
Songle6MT's Avatar
Are you simply talking about the movement of the shifter? Do you think it is hard to move through the gears?
Old Mar 1, 2011 | 07:43 PM
VQ Johnny's Avatar
Gary
^Best advice, I got my G used and that was one of the first things I did and it definitely made a huge difference, I used OEM MTF because I couldn't find Redline locally or I would have gone with that.
Old Mar 1, 2011 | 07:45 PM
tragedycat's Avatar
I have an OEM setup and the only way I can make the shifts smooth is to shift extremely slowly and let the revs drop to where they need to be, and feather the clutch out. AKA take like 3 seconds shifting. So now I just don't worry about it and live with the bucking motions.
Old Mar 1, 2011 | 08:16 PM
Songle6MT's Avatar
Originally Posted by kidtronix
These transmissions have inherently notchy shifting. Thats just the mechanical nature of the transmissions. Nothing can be done about that. If its getting too difficult to move through the gears or certain gears, you may have a larger issue.
I drove three this weekend with this "notchy" shifting. good to hear it's normal as it was a little different. It's not all that notchy though
Old Mar 1, 2011 | 08:32 PM
jibberjabbers's Avatar
We might not find it bad, but our passengers will.
Old Mar 1, 2011 | 08:53 PM
the_sedan's Avatar
learn how to drive? get used to the new setup.
Old Mar 1, 2011 | 09:07 PM
Xet's Avatar
Xet
definitely shouldn't be that hard/take that long, our clutches are really tricky but that's intense.
Old Mar 1, 2011 | 10:34 PM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
Biggest issue by far is the competition between quick-reving and heavy flywheel. Its so easy to leave too much gas on while up-shifting, causing the needle to jump up and miss the rev match to get into gear. If you overshoot it takes a little longer for the revs to drop back down to the match point because of the heavy flywheel. It doesn't work all the time, but I've found I can shift pretty smoothly very quickly by shifting to the next gear quickly as I push in the clutch pedal quickly with my toe, then smoothly letting the clutch back out over a quarter of a second or so with minimal gas until the revs drop from the lower gear's match point to the higher gears match point. The trick is learning when you can add the gas back in, because its not the same for each gear nor is it the same when shifting from higher rpms vs lower rpms...
Keep driving it, and don't get discouraged, you'll find a way to make it quick and smooth. Keep experimenting.
Old Mar 1, 2011 | 10:55 PM
phantomg35coupe's Avatar
ya mine is like what tragedycat says it is...my tranny makes me hate my car and i need to find a way to make it smoother
Old Mar 2, 2011 | 12:56 AM
gary c's Avatar
That just doesn't sound right Tragedycat, you should be able to shift into almost any gear at most RPMs with a flick of the stick except first. I'm not sure from what you describe that using synthetic trans fluid would help. Sound like your syncros are shot and your clutch isn't doing it's job. Are you still under warranty, if so get help!
Gary
