G35 Won't Start
Old Mar 8, 2011 | 03:10 AM
  #31
Choleaoum's Avatar
hey bro, i don't know if you got this fixed but i'm going through the same issue. my car wouldn't start it'd just keep clicking even when trying to jump start it. so i went to my shop, grabbed another battery and bam thing fired right up! sometimes we get a bad batch of batteries, maybe we both got unlucky? lol. i'm still having issues of my car dieing, i think something is draining the **** outta my battery or my alternator is not charging.
Old Mar 8, 2011 | 01:12 PM
  #32
blown420's Avatar
Choleaoum, sorry to hear that...
check out this post here:
http://forums.automotive.com/70/1055...ain/index.html
i was thinking that this was the problem....
but i did get my car to start, i just kept trying to start it... and it finally started...
also, one of the other guys recommended that if you do a push start (MT only) then you should narrow down the problem to the starter.
im 95% sure its my starter now.
Old Mar 9, 2011 | 02:24 PM
  #33
nissandrifter32's Avatar
check the clutch pedal switch..mine was doing the same thing, I changed it and it fixed the problem.u can get it at autozone for like 20 bucks..
Old Mar 9, 2011 | 02:53 PM
  #34
blown420's Avatar
could you explain how the clutch pedal switch would affect this?
Old Mar 9, 2011 | 03:07 PM
  #35
I found the solution through one of the thread on the forums..My car wouldn't crank unless i hit the clutch pedal down real hard...So i change the clutch pedal sensor and my car would turn on right away..
Old Mar 9, 2011 | 03:18 PM
  #36
saywat?'s Avatar
^if the switch is not fully pressed when u depress the clutch the car wont start and will jus make a click sound.
Old Mar 9, 2011 | 03:33 PM
  #37
^yeah thats what was happening to my car..
Old Mar 9, 2011 | 04:13 PM
  #38
saywat?'s Avatar
^was answering blown240s question. not too sure if his questions was legit or not cus its pretty out there
Old Mar 9, 2011 | 04:20 PM
  #39
blown420's Avatar
thanks for the information. do you happen to have the part number you ordered?
did you replace this yourself? if so, do you have instructions?
Old Mar 9, 2011 | 05:02 PM
  #40
go here
http://www.autozone.com/autozone/par...mString=search
I replaced it myself its very easy...
Old Mar 9, 2011 | 06:00 PM
  #41
blown420's Avatar
Old Mar 10, 2011 | 04:01 PM
  #42
blown420's Avatar
update: 180 for hitachi remanufactured starter part (which is the oem part) - 40 for labor --- good deal?
tested the alternator and thats fine...
Old Mar 10, 2011 | 04:09 PM
  #43
saywat?'s Avatar
my bad
Old Mar 10, 2011 | 05:08 PM
  #44
TannerG's Avatar
Originally Posted by saywat?
^how the heck is that a good deal when nissandrifter showed u one for less than $20?
He was talking about the starter, not the switch.
Old Mar 12, 2011 | 08:29 PM
  #45
blown420's Avatar
so it looks like its 200 to replace the starter: 180 for the part and 20 for labor.. the starter itself is the hitachi oem remanufactured replacement
