maintenance help
Old Mar 7, 2011 | 04:25 PM
TootsieRoll7's Avatar
maintenance help
Hi all, I am can't find the answer to my concern so here it is.
1. I have an 03C with Brembos and I have experienced brake not catching at random on usually really cold nights or really wet nights. Sometimes I get the same symptoms if the car is parked outside with heavy rain. Car have new pads and rotors all around since last october. The problem exist prior to brake works and still there after. What can I do to fix this, if any at all?
2. I have difficult time getting to the oil drain plug and the filter with factory jack so what can I do to get better access? Would the portable rams works? Don't think I should be paying for oil change when it's something so simple.
Thanks in advance.
Old Mar 7, 2011 | 04:31 PM
mkvl127's Avatar
i put my entire car up on jack stands..i dont like jacking up the car because i like to drain when the car is sitting level...always lift and lower in this order..front back..back front..theres a jack point in the middle of the car right at the back of the plastic shield on that bar..and for the rear jack it up from the rear diff...theres a vid on infinitihelp.com if you want to actually see it
Old Mar 7, 2011 | 04:42 PM
oh sweet. Thank you for the site. I didn't think I have to jack all 4 corners up. Will try that. Any ideas on the brake issue?
Old Mar 7, 2011 | 10:10 PM
VQ Johnny's Avatar
My brakes feel the same way I believe that the rotors cool pretty quickly and the pads don't bite as well as if the rotors were warm, I find it most noticable on longer highway rides, but after a couple seconds on the brakes it goes away as the pads and rotors start to warm.
Old Mar 7, 2011 | 11:04 PM
gary c's Avatar
If you intend to do the maintenance yourself you need to get the right equipment. Check out Harbor freight, they have a jack for $59 and for a few more $ you can buy jackstands. This small investment will make your life much easier and you can do all your oil changes for years to come. By doing a search you can find out where the best jack/jack stand points are just to be safe or check your manual. Good Luck....
Gary
Old Mar 8, 2011 | 02:41 PM
I have 4 10"-12" (I think) jackstands from Harbor Freight forever. It's just I was used to just jacking the front of the car doing oil change instead of all 4 corners for the G since it's so low. Didn't even realize to try the 4 corners method. Thank you.
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
c_elliott83
Sep 25, 2015 07:55 AM
DRG35R
Sep 16, 2015 05:33 AM
