Base radio in g35 coupe worst I've ever heard.
Old Mar 21, 2011 | 08:55 PM
Iagent's Avatar
I figured that if I replaced the speakers with Boston acoustic 6.5s and installed a 12" powered sub, I would be able to tolerate it. It's just as horrible as before. The head unit must put out all mid bass. It's painful to even be in the car listening to this stereo. That means time to shop for a stereo.
Anyone else have this trouble? Can a crossover be installed inline to the speakers or something until I get something new?
Old Mar 21, 2011 | 09:38 PM
ATGCOUPE801's Avatar
Mine sounds like **** too , I'm gonna put a double din DVD player and all new speakers. 2005 g35 base radio too
Old Mar 21, 2011 | 09:44 PM
icrazy2u's Avatar
Yea, it doesn't get loud at all before it starts distorting. I'm gonna put some speakers in too. I have subs, but can't find a good box that gives me room in my trunk.
Old Mar 21, 2011 | 10:03 PM
tibasnatch's Avatar
I agree.....so I just did a swap....I did a double din dvd....6.5" components up front and a 10" sub....also a 4 channel amp...soo much better....I had the bose and it sucked....do this and u will be happy.
Old Mar 21, 2011 | 10:05 PM
Iagent's Avatar
I have a jl powerwedge max 12" and it just fits in my trunk. It fits tight, but that is good to keep it from moving. I like the idea so much that I bought the 10" version for my boat.
Old Mar 21, 2011 | 10:15 PM
icrazy2u's Avatar
I have a 2 channel amp that came with my fosgates. Would that work for 2 speakers up front? And what did you do with the rest of the speakers in the back, leave em?
Old Mar 21, 2011 | 11:07 PM
Iagent's Avatar
What head unit did you get?
Old Mar 21, 2011 | 11:24 PM
Xet's Avatar
Xet
Are all of your speakers powered by a separate amp? If not then I have no doubt it would be even worse
Old Mar 21, 2011 | 11:51 PM
Iagent's Avatar
Everything is powered by the head unit, and the sub uses an add amp, which gives just a signal to the JL 250 powered sub. Do you suppose that if I used the add amp to power a four channel amp. The head unit would prevail?
Old Mar 22, 2011 | 12:31 AM
Xet's Avatar
Xet
Wait wait, you are running the speakers off the headunit correct? And I don't exactly get what you mean with the sub, but I assume that has it's own aftermarket amp powering it right?
Those speakers almost definitely need their own amp, I can't believe they even are wired to run at the same resistance as stock speakers...
Old Mar 22, 2011 | 12:58 AM
Iagent's Avatar
Oh yes, they work exactly the same. You do realize that I have the Non-Bose system right? I might not have been clear about that.
Stock and aftermarket speakers are 4 ohm. I actually think there is no major difference after the 6.5 change. I just expected so much more.
As for the sub addition, I just ended up with more bass and still have the boom in front. An equalizer would fix this, but the wiring would be a nightmare.
Old Mar 22, 2011 | 01:08 AM
icrazy2u's Avatar
Or you could just power the speakers with a amp... I use a 2 channel amp to power speakers and subs on my old car, and it made the stock speakers louder. So aftermarket speakers should be much louder. I need a 4 channel though.
Old Mar 22, 2011 | 01:11 AM
Affalterbach's Avatar
Do you mean Bose? Because I am fairly satisfied with my Bose sound system and don't plan on touching it. If you meant Base like bottom of the barrel, then yeah most Base sound systems suck *** on any car.
Old Mar 22, 2011 | 01:12 AM
maclovio's Avatar
Maybe i'm use to s%ith...cause I'm happy with my Bose + Sub and a Epic Center Eq for added bass. I'm just thinking about replacing the tweeters
Last edited by maclovio; Mar 22, 2011 at 01:13 AM. Reason: ^^^Posted right before me ahahaha
Old Mar 22, 2011 | 01:15 AM
Iagent's Avatar
NON-Bose
