Anyone done "hard to fill fuel tank" repair?
Old Mar 22, 2011 | 01:42 AM
RiversideS13's Avatar
When I fuel up my car, I can only reach a notch below from "F" and I cannot pour in more fuel as the gun will just keep clicking.
I think I need to have TSB ITB08-041a (FLV valve cover) service done but I am not sure if i can do it by my self because it requires you to install the alloy valve cover blindly. has anyone done this by their self? or has anyone had this done at dealership? if so, how much is that cost? Or will a simple Q-tip clean the sensor will solve my issue?
thanks
i am referring: http://www.infinitig37.com/TSB/1SC29.pdf
Old Mar 22, 2011 | 09:47 AM
walshtj's Avatar
Need to do this also, this problems is such a huge annoyance...
Old Mar 22, 2011 | 09:59 AM
gary c's Avatar
I discovered that it's not always our G35s when it comes to the hard to fill issue. The Chevron near me has one or two pumps that I simply can't fill the gas without it shutting off. No use saying anything to the towel heads that work there they don't know squat or care. No issues at the Shell station, fills up without any problems and I get to listen to their commericals....
Gary
Old Mar 22, 2011 | 06:42 PM
felixsc300's Avatar
Correct me if I'm wrong but I believe this is actually a recall and dealerships will perform the fix free of charce. IIRC one of the few recalls G35s had were faulty fuel tanks between a certain production date.
Old Mar 22, 2011 | 06:59 PM
icrazy2u's Avatar
Yea, I tried filling my 05 up today, and it kept clicking and it barely got halfway. The first time it filled all the way up. This is my second time putting gas in the G.
Old Mar 22, 2011 | 08:55 PM
jebus2006G35's Avatar
put it upside down
Old Mar 22, 2011 | 10:49 PM
the_sedan's Avatar
nope. not a free of charge repair. its a bulletin, not a campaign. i did the flv cover and the new shutter valve on mine. its been doing ok like 90% of the time, other than that....its cuz the pumps pump too fast which will cut them off as well. i wouldnt recommend doing this cuz its completely blind and in the tank and UNLESS you know what you're feeling for.....you more then likely wont get it. and you have to have rather short/small arms to get inside there too.
Old Mar 22, 2011 | 11:05 PM
coupetech's Avatar
best bet is to replace the whole filler neck assembly w/ a new cap while your at it. If you think its the gas station you could be right, the older nozzles wear at the tip or dont pump properly and trip the shut-off baffles.
Old Mar 23, 2011 | 01:51 AM
Yeah that is my concern that I will have to install this part blindly ...i do have a short and tiny hand but i just not sure if i can do the job right. how much do they charge this procedure in dealership?
Old Mar 23, 2011 | 02:10 AM
Affalterbach's Avatar
I've been able to successfully fill my G at the Arco and Shell gas stations near my house. I let it go to E twice when the light came on and I got in about 17 gallons at the pump. IIRC the reserve is like 3-4 gallons?
Old Mar 23, 2011 | 11:54 AM
Nightm4re's Avatar
I had an issue where it wouldnt fill past 1/2 a tank... kept clicking.
Got the repair done.. worked for about a month then started again.
Now i just hold the nosel half in, half out, and cocked sideways and it fills just fine... haha i look stupid but idk, it works.
Old Mar 23, 2011 | 01:00 PM
mrG3FIZZO's Avatar
I have the same problem, look on the bright side... you save money by not pouring in more gas
but then you have to pump again near week end...
Old Mar 23, 2011 | 05:18 PM
Houston5.0Jay's Avatar
need this fix as well ;(
1 line below full is all it will do.
Old Mar 23, 2011 | 08:08 PM
the_sedan's Avatar
i would think somewhere around an hour of labor. 2 at max. if I was doin it, id charge an hour. which is $96 at my dealer. plus parts of course. but id go buy them yourself, see if the parts people will sell it at a better than retail price. good luck.
Old Mar 23, 2011 | 11:54 PM
try the nosel upside down and ull see
