[B][/B]What do you know about Front Camber Arms?
Old Mar 30, 2011 | 08:49 PM
tango5o4's Avatar
^+1
OP.. buy my ****!!
Old Mar 30, 2011 | 08:52 PM
Silver tiburon's Avatar
Originally Posted by Johnnys_Beast_Foo
Just because they look the same doesn't mean the quality is. SPL, Cusco, and SPC are the "original design" camber arms. Everything else are cheap copies.
Your car is lowered X amount of inches. see what your specs are now. then you decide on what to get.
The name brand stuff DOES work as advertised.
The copies and cheap shiit doesn't. end of story.
Whatever SPC, SPL, and Cusco claims to be able to do, WILL IN FACT DO SO.
Bottom line, its going to be your preference.
Agreed. Cheap copies don't work as the originals. ICHIBA arms are not cheap copies, they are the same Cusco arm entirely. Same part, different name. The Godspeed arm is an example of a cheap copy of the ICHIBA/Cusco arm. It has the same look but VERY different craftsmanship if you look closely. You are definitely right about preference. Whatever a person is willing to settle for will determine your definition of cheap and quality in the end.
As far as performance of a part goes I personally wouldn't rely solely on a name brand. I agree that a name brand part will almost always do whats it advertised to do, but the performance level and specs of that part is up to you to research and figure out. Thats what I'm trying to get some input on here. I know what parts are available and how they are supposed to perform according to the manufacturer. But I'm looking for some people with experience and knowledge who are currently using them on their G's. So what's on your car?
Old Mar 30, 2011 | 08:58 PM
ShaneH85's Avatar
Awesome information here guys, now we just need some people that have actually had these different parts
Old Mar 30, 2011 | 09:01 PM
herrschaft's Avatar
Garages.....
Old Mar 30, 2011 | 09:04 PM
Originally Posted by herrschaft
Garage......
An SPC user I see. What's your 2 cents? Did you do the install yourself? If so how was it?
Old Mar 30, 2011 | 09:11 PM
herrschaft's Avatar
I had a shop put them on. One thing I've found, the shims can't be used in conjunction with a BBK. Other then that, no issues and camber/toe are within spec.
The garage feature is a good way to find out what parts people have, if updated.
Old Mar 30, 2011 | 09:33 PM
Do you have shims installed currently?
Old Mar 30, 2011 | 09:38 PM
herrschaft's Avatar
No.
Old Mar 30, 2011 | 10:04 PM
JBF's Avatar
JBF
Ichiba uses lower grade bushings.
Which is why they are cheaper.
Old Mar 30, 2011 | 10:10 PM
Is this coming for a reliable source or are you just saying?
Old Mar 30, 2011 | 10:32 PM
JBF's Avatar
JBF
look up reviews on Ichiba from various forums and even someone who has posted in here. The bushings wear prematurely.
Look, if you want to save a few bucks now, go for it. But you'll wind up spending more in the future.
Old Mar 31, 2011 | 11:58 PM
So I have decided to go with an SPC kit. I have a full set of arms front and rear on the way. I'm planning on doing a write up on the install. I'll keep everyone posted on how the install goes, and how my final alignment turns out.
Old Apr 1, 2011 | 12:07 AM
herrschaft's Avatar
A write up like this: https://g35driver.com/forums/brakes-...tallation.html
Old Apr 1, 2011 | 12:10 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
I have installed and aligned multiple G/Z's with all the camber kits mentioned in this thread.
Ichiba- don't waste your time or money. Even at full positive you only get .5 degree over te stock arms. Plus the bushings go out easily.
SPC- do NOT use the spacers, they cause tons of problems. At your height the shouldn't knock and will give you a real positive adjustment of .75-1.0 degree over the stock arms.
SPL V3 - by far the best camber arms in terms of build quality and functionality. No knocking and real adjustment of 1.0 degree over stock arms.
If you don't plan to lower the car anymore than where it sits now, go with SPC and don't install the shims.
If do plan on going lower in the future, fork over the money for SPL V3's.
Old Apr 1, 2011 | 12:15 AM
  #30
Yes I assume it will be like that exactly. Where did you get your alignment done at after the install? I'm worried most about finding a good alignment guy who will make these parts do what they are intended to.
