Inch drop and negative camber
I just did a drop with an Eibach pro kit all the way around, used the SPC/Eibach rear camber and toe kit, got everything to within specs. Although the right rear was about -4 degrees when we started!!! The front needed little adjustment to get within the recommended specs. Alignment was done professionally. I'm not noticing any irregular wear on the tires.
esotericrider
V36 General Tech Questions
03-04-2019 07:53 PM
Mad A
Not G35 Related
12-08-2015 01:45 PM
