Temperature Control
Old Nov 18, 2004 | 09:11 AM
Grantw35's Avatar
Temperature Control
Took my car in for regular service yesterday and said the temp settings for the driver/passenger was off. Dealer said they could adjust it + or - 12 degrees. Not really happy with the change and don't want to drive 50 miles back to the dealer. Can anyone look into the manual and see if it can be done without the diagnostic controller?
2004 Infiniti G35C IP/5AT/aero/now with chin spoiler/premium/nav/performance/clear corners/K&N filter
Old Nov 18, 2004 | 03:29 PM
Sleuth's Avatar
Re: Temperature Control
why dont you look in the manual?
Old Nov 18, 2004 | 04:12 PM
Grantw35's Avatar
Never mind found it in search as "Climate control"
2004 Infiniti G35C IP/5AT/aero/now with chin spoiler/premium/nav/performance/clear corners/K&N filter <P ID="edit"><FONT class="small"><EM>Edited by Grantw35 on 11/18/04 01:18 PM.</EM></FONT></P>
Old Nov 18, 2004 | 07:44 PM
gersteinp's Avatar
The interior temp can be "trimmed" by plus or minus 6 degrees. I had to do this for my car--it was running too hot for a given setting. Search for my post on Climate Control for the exact method. It's not in the owners manual but is in the service manual.
Old Nov 18, 2004 | 07:54 PM
gersteinp's Avatar
Here-- I found my old post for you:
Just got back from the dealer where they recalibrated my system AND taught me how to do this myself. To recalibrate the climate contro (CC)l:
1) Turn key to ON and turn CC off
2)Turn key OFF and then ON and leave ON
3)Hold down the CC OFF button until readout changes to the calibrate mode.
4)Tap TEMP up until the end (number 51 will show)
5)Hit DEFROST button and then the fan UP button
6)"61" shows. Wait 2 seconds. Then you'll see "0" or whatever trim setting is in there. Calibrate up or down by 6 degrees using the TEMP button. For example, "-3" means that the cabin will be 3 degrees cooler for a given temp setting.
7)Exit calibration mode by hitting AUTO
Old Nov 19, 2004 | 09:08 AM
Grantw35's Avatar
Thanks for the reply. Works great!
Old Mar 22, 2005 | 12:14 AM
froeman's Avatar
What benefit does this provide? Does this mean if you prefer the car to be cooler in the summer, you can calibrate it lower than the lowest setting is supposed to be?
Does this have any effect on the temperature when the fan is blowing with the A/C turned OFF? I've seen some posts where the air coming out of the CC is too warm with the A/C off.
And what exactly does ECON mode do?
Thanks!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
markbilo
Sep 30, 2015 01:33 AM
