Tein H techs Questions
Old May 1, 2011 | 12:36 PM
walshtj's Avatar
+1, Im looking in 350z s-techs...
Old May 1, 2011 | 12:52 PM
CLEANBS's Avatar
had my car aligned with no kits with 350z htechs/tokico hp
got front and rear total toe to 0
front camber -1.75, -1.5
No kits needed
Old May 1, 2011 | 02:11 PM
acid0601's Avatar
No kits needed
Thanks for that Info, so hopefully mine will be the same.
Old May 1, 2011 | 02:31 PM
MADtotheA's Avatar
No kits needed
Awesome! I'm buying mine this week. Was going to go with g35 h techs but you've changed my mind lol. Thanks
Old May 1, 2011 | 02:36 PM
Black07g35coupe's Avatar
yeah i just did 350z h techs 4 days ago. perfect drop with better spring rates. the g 35 h techs will have very minimal drop. waiting for them the "settle" to get an alignment.
Old May 2, 2011 | 12:16 AM
Alex305's Avatar
can you post pic maybe before and after ? and also how is the ride quality like oem or better?
Old May 2, 2011 | 12:22 AM
CLEANBS's Avatar
Ride quality is firmer, handling definitely improved, there is no acceleration squat, braking improved because there is no lean. But I think I was expecting it to be firmer from what I read on here. I would say its a luxurious firm ride. Definitely a upgrade but keep in mine I switched out my oem shocks to tokico hps
Old May 2, 2011 | 05:17 PM
acid0601's Avatar
took it in today for alignment, camber was not to bad form oem specs but will need either toe arm or toe bolt for rear.
Old May 2, 2011 | 05:46 PM
acid0601's Avatar
Does any one know if i will be fine with just toe bolts ? or do they even work properly?? thanks
youngdip631
Lighting
Aug 27, 2015 03:49 PM
zcherub
Aug 27, 2015 09:47 AM
TreeFiddy
Aug 10, 2015 06:50 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
