Hello
We are having trouble locating what screws/10mm need to be removed in order to get my upper dash out.
Video:
So far its
2 behind instrument cluster
2 behind clock
?? left defrost
?? right defrost
?? next to door on right
?? next to door on left
If anyone that has experience in removing their upper dash on a 2004 coupe, it would be very nice if they can chime in and help us, I appreciate it.
Thank you.
Video:
So far its
2 behind clock
?? left defrost
?? right defrost
Thank you.
Quote:
You've got me curious. Why are you doing this?
Changing my interior to black. This upper dash is a god dam bitch thoughOriginally Posted by AuAltima3.5
FSM?You've got me curious. Why are you doing this?
i've taken the entire dash out before but not just the top part. i didnt even know you could take just the top part off by itself.
I hated doing this. WHAT A PITA!!!! Good luck. Its very tideous. You will need to be patient and a good HOW TO.
there is a couple of bolts that need to be removed underneath the top front vents!
Remove the air vents as well. Take off your speedometer and radio it'll be easier to remove it and put the other one back in. Take off anything that seems to be in the way.
i changed mien to black and the upper dash doesn't come off on its own its the actual whole dash even the plastic framework behind the radio. it all has to come out the gauges and stereo glove box and theres vents in the front window for the defrost those have to come out and theres 2 bolts under there.
