n00b bout to school you peoples...grill removal
Old May 18, 2011 | 10:46 AM
  #46
My Key's Avatar
Originally Posted by JOKER
MOTHER FVCKER
I spilled all my blinker fluid.
cheap blinker fluid replacement:
http://kalecoauto.com/index.php?main...&products_id=6
And if you need that extra elbow grease:
http://kalecoauto.com/index.php?main...products_id=32
Old May 18, 2011 | 02:45 PM
  #47
wpg_g35's Avatar
took me 7 seconds the first time lol but longer to put back on...just put the 2 side clips in the grill first and then align all clips and push in gently
Old May 18, 2011 | 02:47 PM
  #48
wpg_g35's Avatar
MOTHER FVCKER
That's what happens when you guys don't do a detailed DIYs.
If you don't know the exact procedures, don't be suggesting random **** and get people in trouble Mark2K8.
best picture ever
Old May 19, 2011 | 02:59 AM
  #49
JOKER's Avatar
CLUB MODERATOR
Need a synthetic fluid and high temp grease.
Those will not do
Old May 19, 2011 | 10:32 AM
  #50
My Key's Avatar
Darn.. too bad
Old May 19, 2011 | 11:50 AM
  #51
Mark2K8's Avatar
I just removed my grill to repaint it. Took 3 seconds literally. I'll post a vid later.
Old May 19, 2011 | 11:54 AM
  #52
bluedevils95's Avatar
Lets see some pix on here!
Old May 19, 2011 | 12:32 PM
  #53
G2FLIP4's Avatar
everything
BAHAHAHAHHAHA Good one!!!
Old May 19, 2011 | 01:43 PM
  #54
Epidel's Avatar
Is there a DIY on how to derail a thread?
Old May 19, 2011 | 01:46 PM
  #55
calcul8's Avatar
I can haz potato?
sabertooth tiger
Old May 19, 2011 | 02:32 PM
  #56
Epidel's Avatar
Originally Posted by calcul8
I see. I has been taught
Old May 19, 2011 | 04:26 PM
  #57
Mark2K8's Avatar
[youtube]WHudpnH0MsU[/youtube]
This is how I take mine off. I dont understand what the other posts are talking about. Pop those bumper plugs type things off and pull the grill from those hook things and thats it.
Old May 19, 2011 | 04:37 PM
  #58
IIIHawKIII's Avatar
finally got some sunshine today. got the pics.
if you pop your hood, you find this hole...
if you look in said hole, you see this...
you can see that the diamond fits thru a square hole. so use a flathead screwdriver and turn it 90 degrees (mine turned easier one way than the other) and it will slip right thru the hole, so your grill just slips off the front.
then once the grill is ready to be installed, you can twist the whole clip and it will come out of it's slot, and you can put it into the grill then just clip it back in. again, it twisted easier one way than the other to come out of the slot as well.
installed grill looks as such...
for my next DIY i will show you how to check the specs on the endline for the rotary girder...
Old May 19, 2011 | 04:59 PM
  #59
Mark2K8's Avatar
Originally Posted by IIIHawKIII
message goes here
lolwut... i didnt have to do that turn 90degree stuff... odd
btw did you skip painting the middle 2 grills? Thats actually a great idea... might do that...
Old May 19, 2011 | 05:09 PM
  #60
IIIHawKIII's Avatar
probably because someone else got frustrated when taking your grill off and broke the clips...cause they didn't have a DIY!!
and i gathered up all the smart assery from this thread and slathered it on those two fins. paint won't stick to it.
