Low tire sensor
Old Nov 21, 2004 | 01:29 AM
urban's Avatar
Low tire sensor
Well I installed my 19" rims about 3 weeks ago and the guys at the shop said that the low tire sensor could not be hooked up to the new wheels, I never gave it any thought until today, as I was driving home and the light came on, I read somewhere that it can be turned of but I cannot find the link.
Also is there a way to hook the sensor back up to the new wheels.
Paul.
2004 G35 Coupe, Loaded.
2004 Lincoln Aviator
1995 Mitsubishi 3000GT VR4 completely modified
1999 VW Jetta
Old Nov 21, 2004 | 09:55 AM
dave's Avatar
Re: Low tire sensor
If you do not have the tire pressure sensors installed on the vehicle (and registered), the low tire pressure warning light comes on after driving for a while (30-45 minutes for me). I have never heard of a way to turn off this self-diagnostic function.
The tire pressure sensors are part of the valve stem on the OEM wheels. Apparently they don't fit on some aftermarket rims. You could try taking the sensors from your OEM rims to another tire shop to see if they can be installed.
If you do get the sensors installed, you have to go to the infiniti dealer to have them registered. They can only be registered with the Consult tool.
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Nov 21, 2004 | 03:29 PM
tsolin01's Avatar
Re: Low tire sensor
I thought the tire pressure monitor only worked if all 4 sensors are present? so if you change out all 4 wheels there won't be a problem?
Tom
Old Nov 21, 2004 | 07:04 PM
dave's Avatar
Re: Low tire sensor
tsolin01,
There is a minor problem if you don't have the sensors -- after driving for a while (30-45 minutes), the low tire pressure light comes on. It goes away when you turn the car off and turn it back on. This is the problem that urban is having.
The tire pressure monitoring system only works correctly if all 4 sensors are present and registered.
GroundingGear™
2003 Yamaha YZF600R
Old Nov 21, 2004 | 10:59 PM
urban's Avatar
Re: Low tire sensor
Thanks for the info, it's funny though as I was driving for 2 weeks like this until the sensor came on. Is there a fuse which I can remove so that the annoying light will disappear off the cluster.
Paul.
1999 VW Jetta
Old Nov 22, 2004 | 12:24 AM
tsolin01's Avatar
Re: Low tire sensor
well i'm changing to my winter setup soon so we'll see what happens...
Tom
Old Nov 22, 2004 | 07:18 PM
dave's Avatar
Re: Low tire sensor
Is there a fuse which I can remove so that the annoying light will disappear off the cluster?
<hr></blockquote>
Not that anyone has found so far.
GroundingGear™
2003 Yamaha YZF600R
Muski_G
Dec 1, 2023 11:11 AM
Jnm07
Aug 6, 2015 03:03 AM
Jay 21
Aug 5, 2015 04:53 PM
stay_tuned
Jul 21, 2015 07:09 PM
