All lights turn on when starting car, car doesn't start.
Old May 18, 2011 | 08:51 PM
Smitty50's Avatar
I turn my car on with key, it doesn't start but has these lights pop up
i turn my car off, then turn it back on and everything is back to normal and the car starts fine. This has happened a couple of times. What seems to be going out/the problem?
Old May 18, 2011 | 10:50 PM
strykez's Avatar
Those lights will always come on when you start the car, it does that so you know they are all still working they go out in a few seconds, as to your problem it could be many things does it crank over when you try to start it or do nothing?
Old May 18, 2011 | 10:54 PM
Smitty50's Avatar
No this is different. It does not crank.
Old May 18, 2011 | 11:03 PM
walshtj's Avatar
It may be the starter or the battery. Those would be the first things I check.
Old May 18, 2011 | 11:15 PM
Smitty50's Avatar
Check to see if the battery isn't dying? How would I do that?
Old May 18, 2011 | 11:42 PM
codeflux's Avatar
you have 1st-gen car with over 100k miles - if you haven't changed the battery yet, it's time to do it in any case.
Old May 19, 2011 | 02:31 PM
walshtj's Avatar
Well any auto part store can do it for you, or if you have a voltmeter to measure the potential difference between the positive and negative terminals. But +1, if you have over 100k you def could use a new battery. I was having similar problems and had the battery replaced and the MAFS cleaned and my car hasn't been acting up at all since. I also reset the ecu with the pedal method once I got home, although that isn't necessary since a new battery does the same thing... GL!
Old May 19, 2011 | 02:32 PM
walshtj's Avatar
BTW I am at 52k and an 06 coupe.
Old May 19, 2011 | 03:02 PM
PAIXAO's Avatar
+ 1 on the battery or starter. I would start with the battery then move on from there.
Old Jun 7, 2011 | 08:44 PM
Smitty50's Avatar
Update.
Battery is fine. I took it to a shop, they had it for a couple days.
They said they remapped the computer and the problem should be fixed
2 days later, it happened again and sometimes the rpm will stall for 2 seconds then go to idle rpm on start up.
This is so frustrating and i gotta take it back in.
So a potential problem is the starter, anything else?
Old Sep 28, 2011 | 11:07 PM
aldo123's Avatar
just wondering if u fixed the problem yet bcoz i have a same problem today
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
realtalk21
Jul 20, 2015 09:07 AM
