Car Turns off on its own please help!
Old May 21, 2011 | 12:44 AM
g35lover209's Avatar
Unhappy Car Turns off on its own please help!
Hey guys I own a 2003 G35 coupe I do have a Intake system other than that the car is stock. I was washing my car this afternoon and after I was finished I took it out for a drive. When I took it out for a drive my car decided to turn off on me while I am driving. When I turn my car back on my check engine light comes on. Before I get my check engine light checked what do you guys think might be the problem? I was guessing possibly alternator problems or maybe I got water in my Intake system please help!
Old May 21, 2011 | 06:50 AM
Blue Dream's Avatar
I drove ttrank's car solo
Did you wash the engine bay? Or the air filter? It might be water in the intake, but I'm curious how it would have gotten in.
Old May 21, 2011 | 08:04 AM
cto917's Avatar
very unlikely that you got water in the intake unless you DRENCHED your filter with water. if you let your car idle, notice any knocking or pinging?
and no to alternator problems, your car wouldnt stop like that, it just wouldnt start.
it could be a lot of things really unless you're more specific on how it stalls out. i'll list em..
timing chain? making the car run lean or rich in higher rpm, but not likely.
oil leaked into cylinder from valve cover, the older gens known for that problem.
bad spark plugs? maybe from the leaking oil, maybe it just needs to be changed.
please elaborate the stall
Old May 21, 2011 | 10:24 AM
R10T_x's Avatar
yea with the little info you posted its kinda hard to figure out what could be wrong your best bet it taking it to like advance auto parts where they'll put the scanner on ur car and tell you what code popped up
Old May 21, 2011 | 12:39 PM
Well the car does have a short ram intake and it does go down to the lower grill of the car. I didnt was the engine bay but just confused on why it turned off. When I let the car idle it runs fine no knocking at all normal idle. Just when I take it out for a drive my car decided to turn off and when I turned it back on my check engine light did turn on but after a little bit of driving the check engine light did turn back off.
Old May 21, 2011 | 01:41 PM
R10T_x's Avatar
soo whats your saying is its all good now?
Old May 21, 2011 | 02:36 PM
No it happened to me late last night turned on the car drove it and turned off on me while im driving. Turned it back on and it didnt turn off on me while I was heading back home. This morning right after I wrote my last post I had to go to the grocery store and on my way to the grocery store my car again decided to turn off. But this time there was no check engine light.
Old May 21, 2011 | 02:51 PM
IIIHawKIII's Avatar
turning off? or dying?
and is it when you are stopped? or when you are literally driving down the road?
Old May 21, 2011 | 03:49 PM
No turns off and it happens when I am driving at a steady speed below 40 mph
Old May 21, 2011 | 08:38 PM
Louisiana G35's Avatar
What grade of fuel are you using? If your using corner store el cheapo your fuel filter could be clogged.
Old May 21, 2011 | 09:44 PM
Dubi2087's Avatar
The same thing use to happen to me. I cleaned my MAF sensor and it has been perfect ever since.
Old May 21, 2011 | 11:35 PM
walshtj's Avatar
+1, I would check your MAFS then maybe your battery..
Old May 21, 2011 | 11:50 PM
broke_as_ajoke's Avatar
its either the fuel filter or the MAFS sensor.. it's not your battery. It must be throwing a code since the car is "turning off". You can check to see what code it is throwing and then u will know for sure or a better idea of whats wrong.
Old May 22, 2011 | 10:09 AM
jrockstarr's Avatar
if it threw a code i would go with MAFS... i don't think a clogged fuel filter would throw a CE light
Old May 22, 2011 | 11:12 AM
herrschaft's Avatar
I would make sure the MAF and throttle body are clean first.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
ddietz97
Jul 26, 2015 06:16 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
