Window motor is possessed!
Old May 23, 2011 | 09:37 AM
JPMM's Avatar
Angry Window motor is possessed!
This weekend I replaced my driver's side motor for the second time in 8 months! The first time I replaced it it worked like a charm. I followed the same process as I did the last time using the procedure outlined in the forum. After installing the rebuilt motor and resetting it the window (after being in the full up position) would roll down a few inches by itself, after several seconds it would roll down a few more inches and repeat this intermittent process until it was all the way down! I tried to put it back up but NG. I then put the side passenger window down (it was hot) and tried the driver side again and I was able to get it up but then the passenger side would not go up! Yesterday I finally got both windows up and disconnected the power to the drivers side window motor to ensure both windows stay up. Any suggestions on how to fix this - it has a mind of it's own!
Old May 23, 2011 | 02:02 PM
jake227's Avatar
Yup, that sounds about right. I did the reset on my driver's side and that fixed the problem........for about 2 weeks. Now it works right about half the time. The other half of the time when I open my door the window drops down about an inch or 2 and doesn't go all the way back up. And sometimes when I have my windows down; if I shut my door my window goes up all by itself.
Old May 23, 2011 | 02:06 PM
LonghornGary's Avatar
Crazy, I guess it's just a matter of time before my window motor goes out.
Old May 23, 2011 | 03:50 PM
avinashchanagal's Avatar
My drivers side went down nd never came back up. i'm getting $150 motor with lifetime warranty from advanced auto store.
Old May 23, 2011 | 03:51 PM
anDross's Avatar
^^ that's what i did.. replaced both and works like a charm now.
Old May 23, 2011 | 04:04 PM
saywat?'s Avatar
either ur not pressing the reset button down fully or hard enough or its not retaining the setting. so gotta replace it again lol.
Old May 23, 2011 | 04:23 PM
JPMM's Avatar
I am sure I am pushing the reset button in all the way. So I guess the reconditioned motor has a reset problem? I haven't even returned the motor I just took out! Any chance it could be the master window switch?
Old May 26, 2011 | 08:06 PM
JPMM's Avatar
So I am taking my G in to have it diagnosed at the Stealership tomorrow for $120. Hopefully once I know what the root cause is I can fix it myself.
Old May 26, 2011 | 08:46 PM
freedonutss's Avatar
I thought that was only me. When I push the up button it will go up half way and just slam down like 4 times then finally goes back up. So advance auto has a lifetime warranty on these window motors? If so thats awesome im going to buy a set.
Old Jun 7, 2011 | 04:42 AM
07Coupe6mt's Avatar
window motors are the worst in these
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
