MAF Sensor problem?
Old Jun 7, 2011 | 01:50 PM
FAULK2's Avatar
MAF Sensor problem?
All right I'm new here so I'd like to say hey to everyone, and I already have a question. I got my 07 DG 6mt coupe with black interior a little over a month ago. I love the thing. I have recently put a Stillen z tube in it and today I installed my JWT Pop-charger and heat shield. I think I might have damaged the MAF sensor when doing so...I unplugged it once and plugged it back in after the install and never started my car up cause I realized i left a gasket out. So I took out the air filter with the MAF sensor housing attached and installed the gasket, and closed the hood. I forgot to plug the MAF sensor back in...So I started it up and noticed this immediately and turned the car off and plugged it in... When I started the car back up, the check engine light, SLIP sign, and VDC off light all came on. Again I unplugged it and plugged it back on, this time with the car running...Now only the check engine light comes on and stays on. I'm pretty sure I screwed something up or damaged it plugging it back in/unplugging it during the install? I tried to be careful with it but I guess that didn't work. The car appears to run fine to me though...I haven't noticed anything wrong power wise I think. I'm just worried about it thats all. What does everyone think?
Also I'm located in Wilmington N.C. just if anybody wanted to know.
Old Jun 7, 2011 | 03:43 PM
Nick05LS's Avatar
Do an ECU reset. It should clear the CEL.
https://g35driver.com/forums/engine-...resetting.html
Old Jun 7, 2011 | 04:23 PM
FAULK2's Avatar
Thanks man, I did that and it worked fine. I saw that guide earlier and was wondering if it would work or not and it did. After I finally got the timing right it worked. I really appreciate it.
chinee
Jun 10, 2024 07:48 PM
jsimonk
Dec 22, 2023 03:49 PM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
broke_as_ajoke
Aug 22, 2015 08:27 PM
newg37
Jul 26, 2015 09:32 AM
