Best Oil Brand/Grade for Revup that eats up oil?
Old Jun 8, 2011 | 08:30 PM
KingCobra's Avatar
I want to try a different oil to see if I can stop this crazy oil consumption (i know about the TSB, ive already replaced my engine once...)
So I'm currently using Castrol Synthetic 5w30 and I already had to add 2 quarts after 3k miles...
I saw the thread on my350z.com comparing the oils...should I go for the thicker oils? Like Mobile1 0w40 or Shell Rotella T-Sync 5w40 or maybe Redline 10w40
What do you guys recommend, and that has actually worked for your revup engines? And lets just say I do some "spirited" driving since I do drive a stick and that's the main reason I got this car to be able to have fun with it...unfortunately Nissan has let me down with this whole oil burning nonsense...
Thanks!
Old Jun 8, 2011 | 08:35 PM
thescreensavers's Avatar
Mr.202?
I would run a thicker oil and go from their
Old Jun 8, 2011 | 08:37 PM
aloooha's Avatar
^what would that be? I head amsoil was pretty good.
Old Jun 8, 2011 | 09:19 PM
gphoenix's Avatar
bro i used regular 5w 30 castrol oil and i have 10,000 miles on the new engine
Old Jun 8, 2011 | 09:32 PM
Mr.202?
yea, no. If you are burning oil why would you buy expensive oil?
By something local, thats heavy weight. Check Bob is the oil guy for more info, they will be of more help then this forum imo
Old Jun 8, 2011 | 10:29 PM
ROD350GT's Avatar
Mobile 1 5w30. You can get it from walmart. Just get the one that's 11.99 for 5q. I was having to put 1 1/2q every 1000 miles. I didn't have to do a oil change. Lol. Good luck.
Old Jun 8, 2011 | 10:40 PM
Revo's Avatar
Well, to get all the crap in your oil out, yeah, you do. Also you still need to change your oil filter...
OP, if your car is still burning oil like crazy, get your engine replaced (again). It doesn't cost you anything (yeah it sucks you need to break it in again, but that's not that big of a deal).
Old Jun 8, 2011 | 10:49 PM
infinitlyfast's Avatar
My personal choice is Royal Purple and Lucas oil stabilizer. I drive at 100 too much really and have no consumption issues, I also use the larger oil filter from the dealer, YOU ARE USING A FACTORY FILTER I HOPE> Fram and Purolator etc are ****! I will post the number of the larger filter when I remember to bring the box in and do it.
Old Jun 8, 2011 | 10:50 PM
ROD350GT's Avatar
Yea I should have said that. You got to change the oil filter. Oil change? No! Not if u put in 5 and 2 comes out after 3000miles. Maintain 5q and just change out the oil filter every 3000. U will be good
Old Jun 8, 2011 | 10:53 PM
ROD350GT's Avatar
Lucas oil stabilizer? Yes!!!
Old Jun 10, 2011 | 03:32 AM
Mr.202?
Filter from the dealer is fram, Purolator's are good. The M45 filter is the larger filter. You need a bit more of oil 0.2 quarts to bring it to the H line on the dipstick
Also Royal Purple is mediocre oil in the VQ
Yes, you still need to get an oil change, stuff will settle in the oil pan.
No! that stuff is crap
Old Jun 10, 2011 | 06:41 AM
Blue Dream's Avatar
I drove ttrank's car solo
Overpriced for what you get. Look at some of the UOAs posted on Driver, RP doesn't perform as well as a lot of synthetic oils in the VQ.
Old Jun 10, 2011 | 10:27 AM
gary c's Avatar
Tim's right....^....Royal Purple will cause you more issues and you don't need to spend your $ on expensive oil if your experiencing OC again. Changing the weight won't solve OC issues take her back to the dealership.
Gary
Old Jun 10, 2011 | 10:42 AM
R10T_x's Avatar
theres a new oil thread every month smh but yea stay away from RP it doesnt work well with our cars
Old Jun 10, 2011 | 02:16 PM
KingCobra's Avatar
^ This isn't just a "whats the best brand" oil thread....I'm looking for something much more specific in regards to the issues our cars have and if theres any oil that is better in that situation
