Navigation problem---Help plz!!
If eject button isn't lighting up (when lights are turned on), then I would guess the unit isn't getting power. Time to start pulling dash apart and checking connectors.
Day/Night button and map
...got it, will try again.
If that fails, will start taking the dash apart. Any place in particular I can look to get a good idea where are the screws are?
Oh and I didn't see a "previous" button at all.
...got it, will try again. If that fails, will start taking the dash apart. Any place in particular I can look to get a good idea where are the screws are?
I think Previous means the "Back" button. Went and tried on my car and simply holding Map + D/N for ~5 seconds caused the diag screen to pop up, no Back button needed.
I highlighted the "Previous(Back)" button in red in this pic.
Start at page 10 to see how the dash pieces are put together: http://www.nicoclub.com/FSM/G35/Coup...5_Coupe/ip.pdf
Looks like at a minimum you need to remove the glove box and the silver trim piece that goes across the dash, to get to that center box.
Thank you LoST180 for the link.
So you don't even press the button on the top of Navi screen when you hold Map+D/N?
I'll have to see if the screen will come out. If not, then taking it apart is what I am doing tonight.
https://g35driver.com/forums/attachm...rness-pic1.jpg
Thanks guys...However I will have to post pone the Navi problem, Until I fix my frame.
Steezy777, thanks for the picture. It does look like a monster on that picture. I hate dealing with wires or anything electrical. It was always over my head!
Progress update: today I turned the engine on and let it run for a little while battery charged. While doing that I decided to give another self diag. a try.
While holding D/N+Map, screen didn't come out. However, when button on the top pressed screen comes out, so the HU has power source. When I turned the headlights switch ON, the screen got power to it, but was still blank.
My assumption is that the Navi system is not getting power do it. So it HAS to be wiring. Not much of a progress, but heading in the right direction!!!
Yeah, you have to push the top button for the display unit to physically pop up.
Did you try the self-diag when you could actually see the screen? Any beeps or anything? What about the eject light on the dvd unit (in the upper glove box) when you turned on the lights?
The reason why I've assumed that the Navi unit is not getting any power, is because then the lights are on, there is no lights of any kind on DVD unit or eject button on the Navi console.
As for the beeps or anything else on the screen...NODAthing, just a blank screen.
I recently downloaded a copy of 7.6 and burned it to a disc. Everything seems to work fine until i start typing in an address.. It pretty much hangs- very frustrated. I'm gonna attempt to reburn it to the disc and see if that helps.
Anyone else experience this with a burned disc?
I have the latest version that I just purchases from NAVTEQ
is there any way to do a master reset? cuz i turned my beeps off on my 2003, and i know theres also a way do set teh brightness on the navi (i havent tried to see how dark it goes tho :/)
So I have the '03 coupe. And my Navigation works sometimes since I first got it back in 2009. I have come to the conclusion that it only works when the temperature outside is hot. I don't know where you guys live...but in the Summer time my NAVI works just fine. And when the Fall and Winter arrives its dead. I noticed this during the winter while it was dead for some time...then one day the sun was out and outside was about 70 degrees and the NAVI powered up. By the afternoon, once the sun went away and the temperature cooled down the NAVI died.. This is the way it works in my car...Alive in the Summer, dead in the Winter.
Anyone else experience this?
