Car doesn't start or jump start but accessories work
Old Jun 14, 2011 | 07:56 PM
khoacalacan's Avatar
Question Car doesn't start or jump start but accessories work
The car doesn't start or jump start but the accessories such as the fans, wipers, signal, radio, etc are working. The car did start up like 30 minutes ago before it doesn't start up. I think it's the starter. Any other ideas I can try to fix the problem or any ideas what the problem can be?
Old Jun 14, 2011 | 08:27 PM
smokinaces05's Avatar
mine was having this issue also but it would start with a jump.
however i ended up finding out my battery was done and had to buy another one, fixed the problem right up;. maybe take your battery out and go get it checked. couldnt hurt.
Old Jun 14, 2011 | 09:41 PM
Battery is good, jump starting it with another car wouldn't do the trick either.
I noticed that the horns are not working. Like honking doesn't work and locking the car doesn't make the honk go off. <--- that's a major clue I think it was the fuses, so I checked most of the fuses, but all of them were good. Any ideas? Maybe the wires? But what wires? I'm lost now.
Btw does anyone know where's the solenoid and the starter? I think that might be the problem too.
Old Jun 14, 2011 | 10:00 PM
04G35NYC's Avatar
Check all the fueses and you might need a new starter.
Old Jun 15, 2011 | 09:57 AM
walshtj's Avatar
+1 on the starter. Since the radio works it isn't the battery. Does it make a clicking sound when you try and turn it over?
Old Jun 15, 2011 | 10:09 AM
NorthDakota's Avatar
Does it turn over at all when you try to start it? Make any weird noises?
Old Jun 15, 2011 | 10:23 AM
No sound, noises, or clicks when i try to start it, it's just quiet lol.
Old Jun 15, 2011 | 10:31 AM
GeeWillikers's Avatar
Walking The Fine Line...
I would think if it were the starter you'd still get the click from the solenoid, but maybe not.
I've never had a starter fail on this car. Or a battery..
Old Jun 15, 2011 | 10:36 AM
No sound makes it sound like either the hot or ground is damaged or came loose from the starter. most of the time the starter has a separate line from the battery, that explains why the accessories work and a jump didn't help. Even a bad starter will make some noise if it has power...
Old Jun 15, 2011 | 10:38 AM
Imma take out the starter today and have autozone do a test on it. I'll let you guys know whatsup later. Thanks for the help ^.^
Btw any ideas with the horn going out? The cruise button still works, so it's probably not the steering wheel. Nvm, I'm just gonna go get the scan tool, should make life easier xD (i hope)
Edit: NortDakota, that is a good point! I'll check the ground wire out before taking the starter off.
Old Jun 15, 2011 | 10:54 AM
walshtj's Avatar
+1 I wouldn't worry about the horn. I am sure it will be fixed when your car is. GL!
Old Jun 15, 2011 | 11:36 AM
I think I found the problem after reading what northdakota said. There was a cut in the grounding wires in the air intake box area and when I look closely one or two of the small wires were cut off. So when I was cleaning the engine bay, it made them disconnected completely.
Although I haven't confirm that this will fix the problem cuz I had to go to school right afterwards, but high chance it is
Old Sep 28, 2011 | 11:08 PM
aldo123's Avatar
did u fix the problems?? i have the same problems with u and my car won't start at all..
Old Sep 28, 2011 | 11:12 PM
Project's Avatar
My power wire nut fell off once. Bought a new starter just because i didnt feel like getting under there and was like damn that all it was.
Old Sep 29, 2011 | 01:02 AM
What he said, it could might be that the ground wire bolt fell off. For mine, one of my ground wires were somehow ripped and disconnected. So I re-soldered the ground wires back together and the car starts up fine again ^.^
