HELP Storing G for 2 months
Old Dec 8, 2004 | 04:50 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by KarateBoy
Even if the battery is disconnected, after 2 months it still should be dischared enough not to crank the starting motor.
The only way to my knowledge to avoid this is to buy a small "charger" that will keep a small flow of electrons to the battery.
Hope this helps.
KarateBoy, Be careful leaving a battery on charge ,even a trickle charger, for any length of time. I've read recently that this can be really bad for the battery.
In this case, I would disconnect the battery to slow or stop the discharge, and recharge slowly on returning. A good battery will accept the recharge easily within a few hours.
Old Dec 10, 2004 | 06:52 PM
G35_coupe_6MT's Avatar
Originally Posted by RBull
I have been storing a vehicle for the.....
Thank you so much. I appreciate this a lot! I have your instructions printed out and when storing comes up, ill be sure to take them with me.
I have one more question... My car is almost 4 months old and it has less than 2000 miles on it. Should I have the oil changed before leaving, after, or both before and after? (58$ for an oil change isnt that cheap but Ill do it twice it if its really advisable). I cant thank you enough for helping me out!
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
wuzz-upp
Oct 3, 2015 04:21 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
