Better Traction
Old Jun 25, 2011 | 02:11 PM
  #31
Ep Drifter's Avatar
i spin some of 1st and a little bit on 2nd but im slightly cambered and my car does tend to slip out soo i kinda get what he's trying to say
Old Jun 26, 2011 | 02:16 AM
  #32
YungThrowed254's Avatar
ichibA REAR CAMBER KITS ANY GOOD ??
Old Jun 26, 2011 | 02:20 AM
  #33
also is i get a camber kit in the rear do i have to get 1 for the front right away
Old Jun 26, 2011 | 02:23 AM
  #34
Beebo's Avatar
No you do not
Old Jun 26, 2011 | 02:27 AM
  #35
4D05G35's Avatar
There are a lot of threads pertaining to those camber kits. Some good some bad. I would do a little bit of searching to base your decision upon. I have the ichiba rear camber + toe and haven't had any problems ..... Yet.
Old Jun 26, 2011 | 02:28 AM
  #36
alright koo so its gnna make a decent difference on my traction because im bout to order them im trying to decide between ichiba and spc theres a 40$ diff lol
Old Jun 26, 2011 | 03:02 AM
  #37
deciden now between spc and spl lol they said spl is the best
Old Jun 26, 2011 | 06:48 AM
  #38
Blue Dream's Avatar
I drove ttrank's car solo
No they suck, DO NOT BUY!!!!!! Here'e what happened to mine. I had 3 other Ichiba products that all failed in one way or another.
Hate to say it but you probably will. I will never buy another Ichiba product ever again.
Old Jun 26, 2011 | 01:54 PM
  #39
4D05G35's Avatar
Yeah I know. I had their spacers with no issues so I went with their Camber arms before doing enough research. I uncoverd several issues with Ichiba products after doing more indepth research. I left it up to him to do the research and decide for himself since I have no first hand experience with their parts failing (Yet). I can just point him in the direction of the info so he can decide for himself.
Old Jun 26, 2011 | 02:18 PM
  #40
thescreensavers's Avatar
Mr.202?
In a straight line no camber at all will be better. Tire sitting / (Cambered) rather then | your having some of the tread not make contact with the ground.
Whats your alignment right now, some negative camber is for the corners.
Only way I got my sedan to go sideways is when it was wet with sh!tty tires and in 4th. at 60 mph, Scary man.
Old Jun 26, 2011 | 03:16 PM
  #41
wpg_g35's Avatar
also it only been happening since i removed the rear seats and everything in the trunk except some thin carpetn lol
I have 275/35/19's on the back of my 06 g35c and in 1st gear I also lose traction and go sideways a bit...however it does depend on the surface you do it on. Fresh black asphalt gives really good traction and hooks up 99% of the time for me. However any other cement even old asphalt will offer much less traction.
If this was happening from 2nd gear for you then that is interesting.
Old Jun 30, 2011 | 06:43 PM
  #42
Clob's Avatar
I mean... I could clutch drop 2nd and lose the rear while on a turn going about 10mph...
Old Jul 4, 2011 | 05:45 PM
  #43
255/45/18 would they fit my stock 18s rear tires
Old Jul 4, 2011 | 07:28 PM
  #44
slim17265's Avatar
although my rear setup is stock. After removing spare tire,tools I noticed on speed shift to 2nd (6mt)I can light the tires up really bad. Upon checking the camber is rather severe. I do not have no where near stock as I have 2-l/4" (at top of tire)(using level and straight edge) negative camber..nothing is bent but it is easy to see tires are canted out at bottom...the plan is to get adjustable camber bars and set it up stock I believe 1-1/4 degrees neg camb. The tires after 6500 mi are worn bad on insides which probably makes the situation worse. Full throttle starts can smoke the tires on black asphalt. The rear tires are Dunlop DRZZA. I am thinking Yokohama 265-40-18 26" dia 9.5 tread width...hopefully this will do it... anybody here that has set their car up approx. like above let me know the outcome..thanx
Old Jul 5, 2011 | 04:09 AM
  #45
wpg_g35's Avatar
I have 100% stock suspension and after getting new tires a few weeks ago I went to a licensed buddy for a 4 wheel alignment. He maxed out the camber adjustment even though it was still visible that negative camber is present.
It did help with traction a bit as there is more tire patch contacting the road instead of the inside of the rear tires.
You can only adjust soo much on the stock suspension, although a little adjustment does improve a bit.
seagrasser
May 3, 2022 09:43 AM
markbilo
Sep 30, 2015 01:33 AM
vamarris
Sep 26, 2015 12:56 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
