Buying new Rims need help...!!!
Old Jun 29, 2011 | 12:42 AM
G_Three_5's Avatar
Im looking to get a set of rim and want to see if this fitment would fit my 04 G35 coupe non brembo.
Front 20x10.5 with 42 offset (4 or 3 inch lip)
Rear 20X10.5 with 25 offset (4 inch lip)
With the front being 10.5 will I still be able to turn since its wider? and will these offset rub the inner side of the car wall?
What tires spec do you guys prefer for these offset?
Please let me know ASAP.
Thanks.
Old Jun 29, 2011 | 12:07 PM
DEMoLITIoN's Avatar
Are you lowered? do you plan on lowering it? You can fit a 10.5 up front no problem. I wouldn't go with anything over a +15 offset.
Old Jun 29, 2011 | 12:12 PM
4DGS's Avatar
You're going to need a pretty big spacer up front for those wheels to clear your suspension on the inside.
IMO, if you have to ask this these probably aren't the wheels for you. The rear is a great fitment but the front is not quite right.
Look for a 20x9.5 +15 20x10.5 +15 set up.
Old Jun 29, 2011 | 12:26 PM
SuperCleanG's Avatar
+1 Good advice!
Old Jun 29, 2011 | 12:47 PM
gary c's Avatar
What tires spec do you guys prefer for these offset? Please let me know ASAP. Thanks.
Those sizes are wrong for the front, you don't want to go any larger than 20X9.5 with 20 offset. Then you can run 245/35X20 tires without issues. Out back I'd keep the same offsets like 18 which will give you a nice lip and you won't need spacers on either end. Out back you can run 285/30X20 which look great and fill your wheel wells.
Gary
Old Jun 29, 2011 | 12:52 PM
LordFappington's Avatar
Thats some interesting wheel sizing. You could just flip them and add spacers to the rear instead. Eventho the lip sizes are slightly different.
Old Jun 29, 2011 | 05:26 PM
G_Three_5's Avatar
Im not planning to lowered it anytime soon. Will it clear with 20X9 with 24 offset and 2.5 inch lip on the front?
Old Jun 29, 2011 | 05:29 PM
G_Three_5's Avatar
If I was to run
Front 20x9 with 24 offset (2.5 inch lip)
Will I need any spacers? and what will be the best tire size for the front and rear if not going to drop the car.
Old Jun 29, 2011 | 05:38 PM
4D05G35's Avatar
Yes.
If I was to run
245/35/20 and 285/30/20 would work.
Old Jun 29, 2011 | 05:48 PM
G_Three_5's Avatar
Thanks for the info..
Old Jun 30, 2011 | 01:04 PM
G_Three_5's Avatar
Oh, what about spacers? do I need them?
Old Jun 30, 2011 | 01:42 PM
droseMVP's Avatar
I would say that rear is perfect but the front is too wide
Old Jun 30, 2011 | 01:49 PM
mistuhlayzee's Avatar
15mm spacers!
Old Jun 30, 2011 | 03:02 PM
CantDieLS's Avatar
If I was to run
i think you are looking solid with that set up. 20x9 up front is fine. and ur offsets are decent too, it depends on what look youre going for, plus you can always add spacers. as for tires, really depends on what look youre going for. If you want a normal fitment you can do 255 up front and 285 or 295s on back. if your looking for a littel stretch 235 or 245 up front is nice and 265 or 275 on the back. if you want some poke and really stretch them you can do 225 up front and 255 on the back. Point is you can really cant go wrong with tire sizes it all depends on what you are look you are trying to achieve
KevinnnVo
Oct 14, 2024 04:33 PM
Jussumman
Dec 22, 2015 10:23 AM
BlackGee35
Jul 31, 2015 11:04 AM
nervseele
Texas
Jul 29, 2015 08:49 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
