Wheel studs suggestions
Old Jun 30, 2011 | 08:21 AM
0me6a7's Avatar
Can you give me some a good suggestion for wheel studs that do not rust?
Old Jun 30, 2011 | 08:31 AM
grovefromnh's Avatar
Only stainless steel won't rust. Nobody make wheel studs for cars due to less shear strength than regular steel. Use closed end lugnuts.
Old Jun 30, 2011 | 10:25 AM
gary c's Avatar
Ah yes, Ft. Bragg I spent a few months there.... Wheel studs are made of hardened steel I seriously doubt if there's a way to keep them from getting rusty. You could slow the process down by painting them and keeping them oiled or get the hell out of N.C. and move to a dry climate!
Gary
Old Jun 30, 2011 | 11:41 AM
0me6a7's Avatar
these look like them might do the job. what ones do we use?
http://www.jegs.com/p/ARP/ARP-Wheel-...47558/10002/-1
Old Jun 30, 2011 | 12:25 PM
RRYDE's Avatar
Yes, the ARP bolts are probably the best bet against rusting. They are CAD plated ( rust inhibitor ).
They do not make a direct replacement for the G35 but these ones will fit - http://www.jegs.com/i/ARP/070/100-77...oductId=747558
They are very long however. They will fit in the front with no modification, but in the rear you will need to cut about 1 inch or so off the end of the stud or dissasemble the rear hub assembly to install.
paolojericho11
Sep 11, 2015 07:08 AM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
JaeXL
Aug 4, 2015 07:43 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
si_driver
Jul 14, 2015 12:29 PM
